pocketBeagle2 EMMC 启动配置
My pocketBeagle2 has an eMMC installed. Since beagle-flasher does not support pocketBeagle2, I used dd to copy the firmware to the eMMC, and then modified the extlinux.conf file of the eMMC (mainly copied the bbplay configuration file). When I started it, the following error occurred:
Loading Environment from nowhere... OK
In:    serial@2860000
Out:   serial@2860000
Err:   serial@2860000
Net:   No ethernet found.
Press SPACE to abort autoboot in 0 seconds
MMC: no card present
Scanning for bootflows in all bootdevs
Seq  Method       State   Uclass    Part  Name                      Filename
Scanning bootdev 'mmc@fa00000.bootdev':
Scanning bootdev 'mmc@fa10000.bootdev':
  0  extlinux     ready   mmc          1  mmc@fa10000.bootdev.part_ /extlinux/ex
tlinux.conf
** Booting bootflow 'mmc@fa10000.bootdev.part_1' with extlinux
BeaglePlay eMMC (extlinux.conf)
1:      eMMC (failsafe)
2:      eMMC disable BCFSERIAL
3:      copy eMMC to microSD
4:      eMMC (debug)
5:      eMMC (default)
Enter choice: 5:        eMMC (default)
Retrieving file: /Image.gz
append: root=/dev/mmcblk0p3 ro rootfstype=ext4 rootwait net.ifnames=0 quiet
Retrieving file: /ti/k3-am6232-pocketbeagle2.dtb
   Uncompressing Kernel Image to 0
## Flattened Device Tree blob at 88000000
Working FDT set to 88000000
   Loading Device Tree to 000000008ffec000, end 000000008ffffced ... OK
Working FDT set to 8ffec000
Starting kernel ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
The system is stuck here and won’t work anymore. Has anyone tried to boot the PocketBeagle2 from eMMC? How did they do it?
Hello @pss.
Look at his Doc. Section boot-modes https://docs.beagleboard.org/pocketbeagle-2.pdf. Using eMMC version, you might need to press user button at boot, which will cause microSD card to go to higher boot order. Try this maybe?
Thank you very much for your reply. I was confused because beagle-flasher was not adapted for pocketbeagle2. However, I referred to the configuration of bb-play and successfully copied the sd card image to emmc and started it successfully.
The latest firmware already supports this feature
@pss glad that worked for you.
