PocketBeagle2 not booting from eMMC
Hi all,
I recently got a PocektBeagle2 and solder a EMMC08G-MV28-01J22 (8GB). Then I flashed the debian image pocketbeagle2-debian-12.9-minimal-arm64-2025-02-13-8gb.img on an SD card in order to flash the eMMC.
The flashing of the eMMC from SD card was successful. When booting from the SD card I can see both devices, eMMC is mmcblk0 and SD mmcblk1.
I’m able to mount the eMMC user partitions mmcblk0p1 with the bootloader binaries, mmcblk0p2 with the rootfs. Also I can see the HW partitions mmcblk0boot0/boot1. In mmcblk0boot0 I have the bootloader tiboot3.bin.
The problem comes when I power-off the board, remove the SD and try to boot from eMMC. The board is doing nothing, not even a message on the UART. No matter if I’m pressing the USER_BTN or not.
After many trials (also flashed tiboot3.bin in partition mmcblk0boot1) I couldn’t boot from eMMC. Then I thought that could be a HW issue.
In board schematics I see that in December 2024 was released version 0.9 of the board with this modification “1. Modify the boot order of non-emmc version, add a pull-down resistor on non-emmc version to force SD boot as primary”.
Is this forcing that the AM62x is trying to boot always from SD card, no matter the status of the USER_BTN input??
Thanks in advance for your replies.
Daniel
Congratulations on getting an eMMC soldered onto the pads; no mean feat.
You’re right; one or more resistors will have to be moved around to boot from it though.
I saw some talk about it on Discord, although I forget who it was…
Thanks a lot, I just checked in discord we need to remove R71 resistor.
Removing the R71 works. When the SD card is not present it boots from eMMC.
Can anyone help indicate the location of the R71, I also had the same problem and need to remove the resistor.
i find it now
pocketbeagle2 revA_241205.pdf (2.2 MB)
After removing R71, the system boots from the onboard eMMC by default.
Is it still possible to boot from the microSD card by pressing the User Button during power-up?
Thank you,
Sergi
yes
(post deleted by author)
