Sir ,
I tried procedure mentioned in http://code.google.com/p/rowboat/wiki/ConfigureAndBuild.
Then i got terminal window shown in below.In that procedure i didn't
use saveenv command In my previous attempt i use it,the result was
same.I got message resetting ,i wait for almost 2 hour but there is
nochange in terminal.
OMAP3530-GP ES3.0, CPU-OPP2 L3-165MHz
DRAM: 128 MB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
Board revision Ax/Bx
Die ID #5ac400030000000004013f8901001001
OMAP3 beagleboard.org #
OMAP3 beagleboard.org # mmc init
mmc1 is available
mmc1 is available
OMAP3 beagleboard.org # setenv bootcmd 'mmc init;fatload mmc 1
80200000 uImage; bootm 80200000'
Unknown command '' - try 'help'
OMAP3 beagleboard.org # setenv bootargs 'mem=128M
androidboot.console=ttyS2 console=tty0 console=ttyS2,115200n8 root=/
dev/mmcblk0p1 rw init=/init rootwait
omapfb.viedo_mode=640x480MR-16@60'
OMAP3 beagleboard.org # reset
resetting ...
thanking advance
with regards Ajish Zacharias
