Hi All,
Brand new user to BBAi64 and new member of forum. I’ve been building a control theory inverted pendulum rig on Teensy 4.1 (NXP i.MXRT1062) for the past year and hitting limits on taking the project further hence the transition to the TI SoC architecture. Full admission, I am in way over my head. I have a couple of questions if this community can point me in the right direction.
I’m not interested in the Linux / AI capabilities right now. I want to port my existing codebase from the Teensy 4.1 to one of the R5F cores and run headless Linux. Where is the best place to start and anything I should watch out for?
How do you define which core owns a peripheral? For instance, how to release an SPI channel from an A72 for use with R5F?
My out of box experience was a bit lackluster. The BBAI64 booted to a black screen with a blinking cursor. SD card LED is solid without SD installed. I’m thinking it is failing to boot from eMMC. I’ve seen conflicting information on resolving this. What is the best way today to load the current eMMC image?
I’ve seen conflicting information on if the the PRU-ICSSG cores are accessible and not disabled by TI. Can I use these cores and can I load the TI PRU firmware for industrial encoder protocols (EnDAT, Hiperface DSL, BiSS)?
Can the eHRPWM be used for FOC motor control algorithms on a dedicated R5F core, or is it unable to use the TI MCU+ motor control toolkit?
Thanks for any info you can provide.
-Mike
