Hi ,
I am working with BeagleBone Black.
From today morning my BBB wont power on.
There is no led blink even power led also.
anybody can help me to resolve the problem.
Hi ,
Sounds like you may have broken it. How are you powering the board? What was the last thing you were ding with the board?
i did connect rs232 to serial converter to this board . . .
connect ground with p9.1 , rx pin to p9.24 and tx pin to p9.26 . . . I did configure UART-1 in my beaglebone . but it work perfectly.
after i connected rs232 the board could not power up. . .
what kind of converter did you connect?
do you have a part number of the converter?
the I/O is 3.3v anything above that and you fry the cpu
Oh . I connected r232 12v converter thats my fault.
thank u for your help.
I need some clarification about BeagleBone.
Currently working in Serial communication and configured UART-1 [ P9_24 =TXD , P9_26 = RXD ] and UART-2 [ P9_21 =TXD , P9_22 = RXD ] in this pins.
I can transmit and receive data from UART_1 to UART_2 and vice verse using simple wires ( see image 2).
Now i try to communicate with external device using CP2102 USB to TTL serial converter 3.3 volts ( image 1).
I have connected TXD (P9_24) pin of BeagleBone to RXD of converter and RXD (P9_26) pin of BeagleBone to TXD of converter.
After this connection made , BeagleBone board’s power off and stopped working .
may i know why this problem happens , please help me o find out the solution to overcome this problem.
The voltage levels have been checked for 3.3 v and the connections were verified. Adaptor Ground → BB Ground
Adaptor TX → BB RX of uart1
Adaptor RX → BB TX of uart1
