I am trying to setup a BeagleBone Black with the following features:
- Boot directly into a QT embedded application (I am using a 4.3" resistive touchscreen cape).
- Good power management features (since this will be embedded and running off battery power).
- No software glitches with the touchscreen firmware (cursor jumping around when you click).
This is what I have found so far:
- If I install any version of Angstrom, then the normal
echo mem>/sys/power/state
command does not work. This command has also never worked for me with any distribution of Debian. I have tried downloading the TI SDK and booting into Arago.
On Arago, “echo mem>/sys/power/state” will put the BBB into sleep mode, so that’s a win. However, I haven’t figured out a way to get QT apps to run on Arago. Also,
support for Arago seems pretty limited. I can’t even get the opkg repo sources configured correctly.
There also appears to be no firmware support for my touchscreen in Arago. I boot, and the touchscreen remains completely blank. However, I don’t see any desktop
or xwindow service installed. I don’t know how to get one installed though to test to see if the touchscreen would work.
- If I install any version of Angstrom after the 06.20.2013 version (https://s3.amazonaws.com/angstrom/demo/beaglebone/BBB-eMMC-flasher-2013.06.20.img.xz),
then the touchscreen cursor will jump around. As a matter of fact, if I install this version (Angstrom-06.20.2013) and then run
opkg udate && opkg upgrade
Then, as part of that process, it will upgrade the kernel from “kernel - 3.8.13-r23a.22” to “kernel - 3.8.13-r23a.49”. After this upgrade, the touchscreen cursor will glitch and jump around.
Getting to the point:
At this point, I would just be happy if I could get a version of Angstrom that had good power management support and support for my touchscreen. I wouldn’t even care if the cursor jumped around.
I have followed the instructions here “http://wiki.beyondlogic.org/index.php/BeagleBoneBlack_Building_Kernel” and here “http://elinux.org/Building_BBB_Kernel” for building my own kernel, and have
been able to do so successfully. However, I don’t have a lot of experience configuring a kernel or writing patches/modules/etc.
Can anyone help me?
Thank you in advance.
