I have installed Ubuntu 12.04.3 onto my BBB and have writen a custom GUI with Gtk which I run calling sudo xinit myprogramname. Everything loads and is displaying the data that I want but after 10 minutes the display blanks and eventually turns off.
After some research on the net I have tried various ways and suggestions of disabling the power management without success.
Does anyone have any suggestions? Thanks in advance!
Thanks for the quick reply. This is one of the sites that I had viewed and tried suggestions from without immediate success. I say immediate because I placed “xset -dpms -display :0” in every X startup file could think of without success. However, once X is started and my application is running I can ssh into the BBB and issue the xset command above and it works as advertised.
Just for information I have tried placing this command in /etc/rc.local, /etc/X11/xinit/xinitrc and /home/ubuntu/.xinitrc without success. I have not tried putting a .xinitrc into root’s home yet.
Might there be any suggestions as to how to script this command?
I have not tried Arch yet. I would imagine it is just as easy to install as Angstrom or Ubuntu. If I can’t get this screen to stay on I might have to give it a whirl.
BTW there is no xorg.conf in the Ubuntu distribution. I tried using “X --configure -config xorg.conf -configdir /etc/X11” to have X generate the xorg.conf but it bombs out stating something about the no drivers available.
I will create one the manual way and see if that works.
