Hello everybody! I recently purchased a beaglebone black, and I got everything. Including a power supply, It is a 5 volt power supply but it doesn’t fit. If somebody could recommend a power supply to me it would be much appreciated. One more thing: To plug in a mouse and a keyboard do I need to use the micro USB or do I use the USB. Thank you!
I might be wrong but I think you should use the USB port for peripherals … get a (powered) USB hub for keyboard/mouse
The board can be powered by USB or 5VDC external power supply. But not both at the same time.
