Power
Hello there,
I will use pocketbeagle for the first time, but I do not know how to power the pocketbeagle. I have to feed it from the computer. How can I feed something like a battery directly? Is it possible to connect the pins directly to the battery? When I look at other projects, it has been realized via usb.
Hello there,
realized via usb.
Pin 1 of P1 can be connected to a 5V power supply.
Pin 14 of P2 can be connected to a lithium Ion/Polymer battery and Pin 16 of
P2 can be connected to a lithium Ion/Polymer batter's "temp" wire. I *think*
this is includes a charging circuit -- if power is supplied via Pin 1 of P1 or
via the USB this pin will charge a lithium Ion/Polymer battery.
It is possible to solder headers to the pins. *I* solder male pins to the
underside and have designed "base boards" with female headers. These base
boards include a power supply circuit. It is also possible (with a
difficulty) to solder female header to the top of the board (there are some
clearance issues).
Thank you very much for your reply.
But if I connect it to pin1 of P1, can I connect it directly to a 5V power supply without using usb?
22 Nisan 2021 Perşembe tarihinde saat 17:52:37 UTC+3 itibarıyla hel...@deepsoft.com şunları yazdı:
Yes. That is what pin1 of P1 is for. It is exactly the same as the DC coax
power connector on the "full sized" Beagle Boards (BeagleBone Black and
Green).
