ppp establish connection on boot debian beaglebone black
I am using a Skywire LE910-SVG cellular modem with a BBB.
I have writting chatscripts and PPP/peers provider scripts that are working well. If I let the BBB boot up normally I can ssh to the device and ‘pon verizon’ to establish a ppp connection manully. Everything works great.
The issue I am trying to resolve is automating this on boot. What is the best way to do this?
Tried adding it to /etc/network/interfaces with:
auto verizon
iface verizon inet ppp0
provider verizon
Does not seam to do anything.
Have also tried to running a simple bash script to do this after the BBB boots
#!/bin/bash
pon verizon
When I execute the script I can see everything connect but I it immediately terminates the connection as I can see in the output with Hangup (SIGHUP)
pppd[1846]: PAP authentication succeeded
pppd[1846]: Could not determine remote IP address: defaulting to 10.64.64.64
pppd[1846]: local IP address 166.154.48.36
pppd[1846]: remote IP address 10.64.64.64
pppd[1846]: primary DNS address 198.224.173.135
pppd[1846]: secondary DNS address 198.224.174.135
pppd[1860]: Hangup (SIGHUP)
pppd[1860]: Modem hangup
pppd[1860]: Connect time 0.0 minutes.
pppd[1860]: Sent 0 bytes, received 0 bytes.
pppd[1860]: Connection terminated.
Any solutions out there?
Kind Regards,
Matt
Hi there
Matt Maher Peterson wrote:
I am using aSkywire LE910-SVG cellular modem
<http://nimbelink.com/skywire-cellular-modem-lte/&gt;with a BBB.
and 'pon verizon' to establish a ppp connection manully. Everything
works great.
auto verizon
       provider verizon
This should work, but is not a very good idea.
Use: up ( pon provider ) &
boots
#!/bin/bash
pon verizon
Hangup (SIGHUP)
Weird.
  pppd[1860]: *Hangup (SIGHUP)*
How long does this take?
Try debug.
Does the modem want flow control or modem control lines?
Rob
