I used the file BBB-eMMC-flasher-debian-7.5-2014-05-14-2gb.img.xz to flash my beaglebone black with debian 7.5.
Everything went fine but now the idea is that I will make changes to this debian and after create a flasher image from it to copy it to my other boards.
I tested it already in the past but didn’t work. This is what I tried now to start from scratch but it did not work:
- flash the BBB-eMMC-flasher-debian-7.5-2014-05-14-2gb.img.xz to the beaglebone
- Reboot the beaglebone without SD card
- Debian is booted and I put an empty SD card back
- I went to the folder /opt/scripts/tools/eMMC and did a git pull
- launched beaglebone-black-make-microSD-flasher-from-eMMC.sh
Here it went wrong, this is the output of the command:
==> Erasing: /dev/mmcblk1
108+0 records in
108+0 records out
113246208 bytes (113 MB) copied, 8.81422 s, 12.8 MB/s
108+0 records in
108+0 records out
113246208 bytes (113 MB) copied, 6.61329 s, 17.1 MB/s
==> Erasing: /dev/mmcblk1 complete
!==> Could not find /boot/SOC.sh, no defaults are loaded
Writing bootloader to [/dev/mmcblk1]
==> Figuring out options for SPL U-Boot copy …
===> Will use :
==> Figuring out options for U-Boot copy …
===> Will use :
==> Copying SPL U-Boot with dd if= of=/dev/mmcblk1
dd: opening `': No such file or directory
Traceback (last called is first):
_dd_bootloader() in ./functions.sh:717
prepare_drive_reverse() in ./functions.sh:1354
main() in ./beaglebone-black-make-microSD-flasher-from-eMMC.sh:42
The command dd if=${dd_spl_uboot_backup} of=${destination} ${dd_spl_uboot} exited with exit code 1.
Tearing Down script environment
==> Unmounting /tmp
umount: /tmp: not mounted
==> Unmounting /boot
umount: /boot: not mounted
==> Stopping Cylon LEDs …
==> Setting LEDs to
==> Force writeback of eMMC buffers by Syncing: /dev/mmcblk1
./functions.sh: line 204: 5973 Terminated cylon_leds
100000+0 records in
100000+0 records out
51200000 bytes (51 MB) copied, 2.55928 s, 20.0 MB/s
===> Syncing: /dev/mmcblk1 complete
==> This script took 44 seconds to run
==> Setting LEDs to
What am I doing wrong, I see that /boot/ is almost empty and the desired files are in /boot/uboot/. Do I need to copy them over to /boot/ ?
Thanks for your help!
Kind regards,
Dries
