lets see 2 minute delay, with an ubuntu root filesystem.
I bet you do not have your Ethernet plugged in..
console=ttyO2,115200n8 ,
already available in my boot args.
Are there any additional steps that need to be taken to get kernel debug messages on the serial ports.
OMAP3 beagleboard.org # printenv
baudrate=115200
beaglerev=xMC
bootcmd=mmc dev ${mmcdev}; if mmc rescan; then if run userbutton; then setenv bootenv uEnv.txt;else setenv bootenv user.txt;fi;echo S;
bootdelay=1
bootenv=uEnv.txt
bootfile=uImage.beagle
buddy=none
buddy2=none
camera=none
defaultdisplay=dvi
dieid#=368e00029ff80000016849a906024023
dvimode=1280x720MR-16@60
ethact=usb_ether
importbootenv=echo Importing environment from mmc …; env import -t $loadaddr $filesize
loadaddr=0x80200000
loadbootenv=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${bootenv}
loadramdisk=fatload mmc ${mmcdev}:${mmcpart} ${rdaddr} ramdisk.gz
loaduimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} zImage
loaduimagefat=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} zImage
mmcargs=setenv bootargs console=${console} ${optargs} mpurate=${mpurate} buddy=${buddy} buddy2=${buddy2} camera=${camera} wl12xx_clk=}
mmcboot=echo Booting from mmc …; run mmcargs; bootz ${loadaddr}
mmcdev=0
mmcpart=1
mmcroot=/dev/mmcblk0p2 ro
mmcrootfstype=ext4 rootwait fixrtc
mpurate=auto
nandargs=setenv bootargs console=${console} ${optargs} mpurate=${mpurate} buddy=${buddy} buddy2=${buddy2} camera=${camera} wl12xx_clk}
nandboot=echo Booting from nand …; run nandargs; nand read ${loadaddr} 280000 400000; bootz ${loadaddr}
nandroot=ubi0:rootfs ubi.mtd=4
nandrootfstype=ubifs
ramargs=setenv bootargs console=${console} ${optargs} mpurate=${mpurate} buddy=${buddy} buddy2=${buddy2} vram=${vram} omapfb.mode=${d}
ramboot=echo Booting from ramdisk …; run ramargs; bootz ${loadaddr}
ramroot=/dev/ram0 rw ramdisk_size=65536 initrd=0x81000000,64M
ramrootfstype=ext2
rdaddr=0x81000000
stderr=serial
stdin=serial
stdout=serial
usbtty=cdc_acm
userbutton=if gpio input 173; then run userbutton_xm; else run userbutton_nonxm; fi;
userbutton_nonxm=gpio input 7;
userbutton_xm=gpio input 4;
vram=12M
wl12xx_clk=none
Really, do you want to bet on that?
cat /proc/cmdline
sorry for direct post but i have a question regarding kernel booting
i had install a new kernel ( linux-image-3.2.0.49-omap ) on my Beagleboard-XM with this command
sudo apt-get install linux-image-3.2.0.49-omap
it get successfully installed with complete module but when it get boot and power on.
and after run a command uname -r it is still showing me older kernel version which is 3.6.8.x4.
my question is how to boot my new kernel which is recently installed i know that it will require some u-boot or boot-loader but i doesn’t find any update regarding this issue for your kind information it generates initrd.img and System.config file but doesn’t generate any file called uImage or zimage
"sudo flash-kernel 3.2.0.49-omap"
Regards
Sid.
Thank you , I am able to enable the serial port output.
I did login as user : ubuntu password : temppwd
I tried to change by - > passwd root ,but not possible it seems.
May I know the password for root ?
ubuntu by default does not create a root user...
Is it possible to create rootfs with root user option ?
"sudo su"
I have gone through this link to create the rootfs from scratch https://wiki.ubuntu.com/ARM/RootfsFromScratch , is this correct ?
if wrong , could you point me to the link with the steps to create root file-system from scratch.
ARM/RootfsFromScratch - Ubuntu Wiki , is this correct ?
No one maintains "rootstock" anymore... Those instructions are
old/outdated/etc...
If you "really" want to create a root file system from scratch.. Look
up a tool called 'debootstrap'...
https://wiki.debian.org/Debootstrap
