I have formatted and created two partitions in SD Card,
/media/boot - size 120 MB
/media/rootfs - size 2.7 GB
After compiling the u-boot source ,I copied the MLO , u-bbot.bin,u-boot.img , uEnv.txt , uImage , zImage to FAT32 partition /media/BOOT.
Extracted rootfs tar to the partition /media/rootfs.
But after inserting the sd card to my target beagle board xm (rev C1) , it failed to start up with u-boot and no output in the terminal.
I have my actual sd card shipped with angstorm image for backup , and using the new transcend 4gb sd card for this testing.
Attached the environment variables present in the target.
Please suggest whether the boot environment variables needs to be modified ?
I used the uEnv.txt as below,
#Camera: Uncomment to enable:
#http://shop.leopardimaging.com/product.sc?productId=17
#camera=li5m03
#SPI: enable for userspace spi access on expansion header
#buddy=spidev
#LSR COM6L Adapter Board
#http://eewiki.net/display/linuxonarm/LSR+COM6L+Adapter+Board
#First production run has unprogramed eeprom:
#buddy=lsr-com6l-adpt
#LSR COM6L Adapter Board + TiWi5
#wl12xx_clk=wl12xx_26mhz
#These are now set by default: uncomment/change if you need something else
#defaultdisplay=dvi
#dvimode=1280x720MR-16@60
console=ttyS2,115200n8 mmcroot=/dev/mmcblk0p2 rw rootdelay=1
mmcrootfstype=ext4 rootwait fixrtc
Thanks.
uEnv.txt (1.98 KB)
