Recently I reloaded angstromg for my BBB but can´t connect it trought ssh. I need to do this because I don´t have a monitor and I only get acces to the web by wifi but I need to install the drivers first on my beaglebone, what can I do to get acces to my bbb again? also my laptop doesn´t recognize the bbb when plug it with usb but I know it works because I tried at work and I had no problem, except for the ssh that didn’t work either. I’am using the latest distribution I found of angstrom and an bbb A5A.
When you reloaded Angstrom, did you go through the getting started page step by step? Including driver installation? http://beagleboard.org/static/beaglebone/latest/README.htm
When you finished flashing, did you remove the SD card from the BBB?
