problem in Booting kernel From SD card- OMAP3530
We have OMAP3530 board from Boardcon company. It is the same as EMA
DEV3530. They have given the board with preloaded boot files in NAND.
So, when we boot it from NAND , it works fine. But, when we followed
the instructions in the manual given by you and try to boot the board
from a SD card, it doesn't work. We have used the Boot files given in
the CD-ROM. Please let us know what went wrong , and suggest a
possible solution.
U-Boot 2009.11-svn12 ( 8��月 16 2010 - 17:25:40) OMAP3530-GP ES3.1, CPU-
OPP2 L3-165MHz OMAP3 SBC3530 + LPDDR/NAND I2C: ready DRAM: 128 MB
NAND: 256 MiB
    In: serial
Out: serial
Err: serial
Ethernet MAC address: 02:c0:05:01:b0:05
Die ID #170000040000000004036ac00501b005
Net: smc911x-0 Hit any key to stop autoboot: 0
mmc1 is available
reading boot.scr
Unable to read "boot.scr" from mmc 0:1
reading uImage
3195484 bytes
read Booting from mmc ... ## Booting kernel from Legacy Image at
82000000 ...
Image Name: Angstrom/2.6.32/beagleboard
Image Type: ARM Linux Kernel
Image (uncompressed) Data Size: 3195420 Bytes = 3 MB Load Address:
80008000 Entry Point: 80008000 Verifying Checksum ... OK Loading
Kernel Image ... OK
OK Starting kernel ...
booting stops here.. what could be the problem for that? please
suggest me some solutions
