Thanks for taking the time, and giving your inputs.
=> printenv
arch=arm
args_mmc=run finduuid;setenv bootargs console=${console} ${cape_uboot} root=PARTUUID=${uuid} ro rootfstype=${mmcrootfstype} ${uboot_detected_capes} ${cmdline}
args_mmc_old=setenv bootargs console=${console} ${optargs} ${cape_uboot} root=${oldroot} ro rootfstype=${mmcrootfstype} ${uboot_detected_capes} ${cmdline}
args_mmc_uuid=setenv bootargs console=${console} ${optargs} ${cape_uboot} root=UUID=${uuid} ro rootfstype=${mmcrootfstype} ${uboot_detected_capes} ${cmdline}
args_netinstall=setenv bootargs ${netinstall_bootargs} ${optargs} ${cape_uboot} root=/dev/ram rw ${uboot_detected_capes} ${cmdline}
args_uenv_root=setenv bootargs console=${console} ${optargs} ${cape_uboot} root=${uenv_root} ro rootfstype=${mmcrootfstype} ${uboot_detected_capes} ${cmdline}
baudrate=115200
board=am335x
board_eeprom_header=undefined
board_name=A335BNLT
board_rev=EIA0
board_serial=2046SBI10516
boot=${devtype} dev ${mmcdev}; if ${devtype} rescan; then gpio set 54;setenv bootpart ${mmcdev}:1; if test -e ${devtype} ${bootpart} /etc/fstab; then setenv mmcpart 1;fi; echo Checking for: /uEnv.txt …;if test -e ${devtype} ${bootpart} /uEnv.txt; then if run loadbootenv; then gpio set 55;echo Loaded environment from /uEnv.txt;run importbootenv;fi;echo Checking if uenvcmd is set …;if test -n ${uenvcmd}; then gpio set 56; echo Running uenvcmd …;run uenvcmd;fi;fi; echo Checking for: /${script} …;if test -e ${devtype} ${bootpart} /${script}; then gpio set 55;setenv scriptfile ${script};run loadbootscript;echo Loaded script from ${scriptfile};gpio set 56; run bootscript;fi; echo Checking for: /boot/${script} …;if test -e ${devtype} ${bootpart} /boot/${script}; then gpio set 55;setenv scriptfile /boot/${script};run loadbootscript;echo Loaded script from ${scriptfile};gpio set 56; run bootscript;fi; echo Checking for: /boot/uEnv.txt …;for i in 1 2 3 4 5 6 7 ; do setenv mmcpart ${i};setenv bootpart ${mmcdev}:${mmcpart};if test -e ${devtype} ${bootpart} /boot/uEnv.txt; then gpio set 55;load ${devtype} ${bootpart} ${loadaddr} /boot/uEnv.txt;env import -t ${loadaddr} ${filesize};echo Loaded environment from /boot/uEnv.txt;if test -n ${dtb}; then echo debug: [dtb=${dtb}] … ;setenv fdtfile ${dtb};echo Using: dtb=${fdtfile} …;fi;echo Checking if uname_r is set in /boot/uEnv.txt…;if test -n ${uname_r}; then gpio set 56; setenv oldroot /dev/mmcblk${mmcdev}p${mmcpart};echo Running uname_boot …;run uname_boot;fi;fi;done;fi;
boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr}
boot_efi_binary=if fdt addr ${fdt_addr_r}; then bootefi bootmgr ${fdt_addr_r};else bootefi bootmgr ${fdtcontroladdr};fi;load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} efi/boot/bootarm.efi; if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r};else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi
boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}${boot_syslinux_conf}
boot_fdt=try
boot_fit=0
boot_net_usb_start=usb start
boot_prefixes=/ /boot/
boot_script_dhcp=boot.scr.uimg
boot_scripts=boot.scr.uimg boot.scr
boot_syslinux_conf=extlinux/extlinux.conf
boot_targets=mmc0 legacy_mmc0 mmc1 legacy_mmc1 pxe dhcp
bootcmd=if test ${boot_fit} -eq 1; then run update_to_fit; fi; run findfdt; run init_console; run envboot; run distro_bootcmd
bootcmd_dhcp=run boot_net_usb_start; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;setenv efi_fdtfile ${fdtfile}; if test -z “${fdtfile}” -a -n “${soc}”; then setenv efi_fdtfile ${soc}-${board}${boardver}.dtb; fi; setenv efi_old_vci ${bootp_vci};setenv efi_old_arch ${bootp_arch};setenv bootp_vci PXEClient:Arch:00010:UNDI:003000;setenv bootp_arch 0xa;if dhcp ${kernel_addr_r}; then tftpboot ${fdt_addr_r} dtb/${efi_fdtfile};if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r}; else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi;fi;setenv bootp_vci ${efi_old_vci};setenv bootp_arch ${efi_old_arch};setenv efi_fdtfile;setenv efi_old_arch;setenv efi_old_vci;
bootcmd_legacy_mmc0=gpio clear 56; gpio clear 55; gpio clear 54; gpio set 53; setenv devtype mmc; setenv mmcdev 0; setenv bootpart 0:1 ; run boot
bootcmd_legacy_mmc1=gpio clear 56; gpio clear 55; gpio clear 54; gpio set 53; setenv devtype mmc; setenv mmcdev 1; setenv bootpart 1:1 ; run boot
bootcmd_mmc0=devnum=0; run mmc_boot
bootcmd_mmc1=devnum=1; run mmc_boot
bootcmd_pxe=run boot_net_usb_start; dhcp; if pxe get; then pxe boot; fi
bootcount=5
bootdelay=0
bootdir=/boot
bootenv=uEnv.txt
bootenvfile=uEnv.txt
bootfile=zImage
bootm_size=0x10000000
bootpart=0:2
bootscript=echo Running bootscript from mmc${bootpart} …; source ${loadaddr}
console=ttyS0,115200n8
cpu=armv7
dfu_alt_info_emmc=rawemmc raw 0 3751936;boot part 1 1;rootfs part 1 2;MLO fat 1 1;MLO.raw raw 0x100 0x100;u-boot.img.raw raw 0x300 0x1000;u-env.raw raw 0x1300 0x200;spl-os-args.raw raw 0x1500 0x200;spl-os-image.raw raw 0x1700 0x6900;spl-os-args fat 1 1;spl-os-image fat 1 1;u-boot.img fat 1 1;uEnv.txt fat 1 1
dfu_alt_info_mmc=boot part 0 1;rootfs part 0 2;MLO fat 0 1;MLO.raw raw 0x100 0x100;u-boot.img.raw raw 0x300 0x1000;u-env.raw raw 0x1300 0x200;spl-os-args.raw raw 0x1500 0x200;spl-os-image.raw raw 0x1700 0x6900;spl-os-args fat 0 1;spl-os-image fat 0 1;u-boot.img fat 0 1;uEnv.txt fat 0 1
dfu_alt_info_ram=kernel ram 0x80200000 0x4000000;fdt ram 0x80f80000 0x80000;ramdisk ram 0x81000000 0x4000000
distro_bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done
eeprom_bbb_header=i2c dev 0; i2c mw 0x50 0x00.2 aa; i2c mw 0x50 0x01.2 55; i2c mw 0x50 0x02.2 33; i2c mw 0x50 0x03.2 ee; i2c mw 0x50 0x04.2 41; i2c mw 0x50 0x05.2 33; i2c mw 0x50 0x06.2 33; i2c mw 0x50 0x07.2 35; i2c mw 0x50 0x08.2 42; i2c mw 0x50 0x09.2 4e; i2c mw 0x50 0x0a.2 4c; i2c mw 0x50 0x0b.2 54;
eeprom_bbbl_footer= i2c mw 0x50 0x0c.2 42; i2c mw 0x50 0x0d.2 4c; i2c mw 0x50 0x0e.2 41; i2c mw 0x50 0x0f.2 32;
eeprom_bbbw_footer= i2c mw 0x50 0x0c.2 42; i2c mw 0x50 0x0d.2 57; i2c mw 0x50 0x0e.2 41; i2c mw 0x50 0x0f.2 35;
eeprom_bbgg_footer= i2c mw 0x50 0x0c.2 47; i2c mw 0x50 0x0d.2 47; i2c mw 0x50 0x0e.2 31; i2c mw 0x50 0x0f.2 41;
eeprom_beaglelogic= i2c mw 0x50 0x00.2 aa; i2c mw 0x50 0x01.2 55; i2c mw 0x50 0x02.2 33; i2c mw 0x50 0x03.2 ee; i2c mw 0x50 0x04.2 41; i2c mw 0x50 0x05.2 33; i2c mw 0x50 0x06.2 33; i2c mw 0x50 0x07.2 35; i2c mw 0x50 0x08.2 42; i2c mw 0x50 0x09.2 4c; i2c mw 0x50 0x0a.2 47; i2c mw 0x50 0x0b.2 43; i2c mw 0x50 0x0c.2 30; i2c mw 0x50 0x0d.2 30; i2c mw 0x50 0x0e.2 30; i2c mw 0x50 0x0f.2 41;
eeprom_blank=i2c dev 0; i2c mw 0x50 0x00.2 ff; i2c mw 0x50 0x01.2 ff; i2c mw 0x50 0x02.2 ff; i2c mw 0x50 0x03.2 ff; i2c mw 0x50 0x04.2 ff; i2c mw 0x50 0x05.2 ff; i2c mw 0x50 0x06.2 ff; i2c mw 0x50 0x07.2 ff; i2c mw 0x50 0x08.2 ff; i2c mw 0x50 0x09.2 ff; i2c mw 0x50 0x0a.2 ff; i2c mw 0x50 0x0b.2 ff; i2c mw 0x50 0x0c.2 ff; i2c mw 0x50 0x0d.2 ff; i2c mw 0x50 0x0e.2 ff; i2c mw 0x50 0x0f.2 ff; i2c mw 0x50 0x10.2 ff; i2c mw 0x50 0x11.2 ff; i2c mw 0x50 0x12.2 ff; i2c mw 0x50 0x13.2 ff; i2c mw 0x50 0x14.2 ff; i2c mw 0x50 0x15.2 ff; i2c mw 0x50 0x16.2 ff; i2c mw 0x50 0x17.2 ff; i2c mw 0x50 0x18.2 ff; i2c mw 0x50 0x19.2 ff; i2c mw 0x50 0x1a.2 ff; i2c mw 0x50 0x1b.2 ff; i2c mw 0x50 0x1c.2 ff; i2c mw 0x50 0x1d.2 ff; i2c mw 0x50 0x1e.2 ff; i2c mw 0x50 0x1f.2 ff;
eeprom_dump=i2c dev 0; i2c md 0x50 0x00.2 20;
eeprom_pocketbeagle= i2c mw 0x50 0x00.2 aa; i2c mw 0x50 0x01.2 55; i2c mw 0x50 0x02.2 33; i2c mw 0x50 0x03.2 ee; i2c mw 0x50 0x04.2 41; i2c mw 0x50 0x05.2 33; i2c mw 0x50 0x06.2 33; i2c mw 0x50 0x07.2 35; i2c mw 0x50 0x08.2 50; i2c mw 0x50 0x09.2 42; i2c mw 0x50 0x0a.2 47; i2c mw 0x50 0x0b.2 4c; i2c mw 0x50 0x0c.2 30; i2c mw 0x50 0x0d.2 30; i2c mw 0x50 0x0e.2 41; i2c mw 0x50 0x0f.2 32;
eeprom_program=if test $board_eeprom_header = bbb_blank; then run eeprom_dump; run eeprom_blank; run eeprom_bbb_header; run eeprom_dump; reset; fi; if test $board_eeprom_header = bbbl_blank; then run eeprom_dump; run eeprom_blank; run eeprom_bbb_header; run eeprom_bbbl_footer; run eeprom_dump; reset; fi; if test $board_eeprom_header = bbbw_blank; then run eeprom_dump; run eeprom_blank; run eeprom_bbb_header; run eeprom_bbbw_footer; run eeprom_dump; reset; fi; if test $board_eeprom_header = pocketbeagle_blank; then run eeprom_dump; run eeprom_blank; run eeprom_pocketbeagle; run eeprom_dump; reset; fi; if test $board_eeprom_header = bbgg_blank; then run eeprom_dump; run eeprom_blank; run eeprom_bbb_header; run eeprom_bbgg_footer; run eeprom_dump; reset; fi; if test $board_eeprom_header = beaglelogic_blank; then run eeprom_dump; run eeprom_blank; run eeprom_beaglelogic; run eeprom_dump; reset; fi;
efi_dtb_prefixes=/ /dtb/ /dtb/current/
envboot=mmc dev ${mmcdev}; if mmc rescan; then echo SD/MMC found on device ${mmcdev};if run loadbootscript; then run bootscript;else if run loadbootenv; then echo Loaded env from ${bootenvfile};run importbootenv;fi;if test -n $uenvcmd; then echo Running uenvcmd …;run uenvcmd;fi;fi;fi;
eth1addr=2c:ab:33:6a:bb:60
ethact=cpsw
ethaddr=2c:ab:33:6a:bb:5e
failumsboot=echo; echo FAILSAFE: U-Boot UMS (USB Mass Storage) enabled, media now available over the usb slave port …; ums 0 ${devtype} 1;
fdt_addr_r=0x88000000
fdtaddr=0x88000000
fdtfile=undefined
findfdt=echo board_name=[$board_name] …; if test $board_name = A335BLGC; then setenv fdtfile am335x-beaglelogic.dtb; fi; if test $board_name = A335BONE; then setenv fdtfile am335x-bone.dtb; fi; if test $board_name = A335BNLT; then echo board_rev=[$board_rev] …; if test $board_rev = GH01; then setenv fdtfile am335x-boneblack.dtb; elif test $board_rev = BBG1; then setenv fdtfile am335x-bonegreen.dtb; elif test $board_rev = BP00; then setenv fdtfile am335x-pocketbone.dtb; elif test $board_rev = GW1A; then setenv fdtfile am335x-bonegreen-wireless.dtb; elif test $board_rev = GG1A; then setenv fdtfile am335x-bonegreen-gateway.dtb; elif test $board_rev = AIA0; then setenv fdtfile am335x-abbbi.dtb; elif test $board_rev = EIA0; then setenv fdtfile am335x-boneblack.dtb; elif test $board_rev = ME06; then setenv fdtfile am335x-bonegreen.dtb; elif test $board_rev = OS00; then setenv fdtfile am335x-osd3358-sm-red.dtb; elif test $board_rev = OS01; then setenv fdtfile am335x-osd3358-sm-red-v4.dtb; else setenv fdtfile am335x-boneblack.dtb; fi; fi; if test $board_name = A335PBGL; then setenv fdtfile am335x-pocketbeagle.dtb; fi; if test $board_name = BBBW; then setenv fdtfile am335x-boneblack-wireless.dtb; fi; if test $board_name = BBG1; then setenv fdtfile am335x-bonegreen.dtb; fi; if test $board_name = BBGW; then setenv fdtfile am335x-bonegreen-wireless.dtb; fi; if test $board_name = BBGG; then setenv fdtfile am335x-bonegreen-gateway.dtb; fi; if test $board_name = BBBL; then setenv fdtfile am335x-boneblue.dtb; fi; if test $board_name = BBEN; then setenv fdtfile am335x-sancloud-bbe.dtb; fi; if test $board_name = BBELITE; then setenv fdtfile am335x-sancloud-bbe-lite.dtb; fi; if test $board_name = OS00; then setenv fdtfile am335x-osd3358-sm-red.dtb; fi; if test $board_name = OS01; then setenv fdtfile am335x-osd3358-sm-red-v4.dtb; fi; if test $board_name = A33515BB; then setenv fdtfile am335x-evm.dtb; fi; if test $board_name = A335X_SK; then setenv fdtfile am335x-evmsk.dtb; fi; if test $board_name = A335_ICE; then setenv fdtfile am335x-icev2.dtb; fi; if test $fdtfile = undefined; then setenv board_name A335BNLT; setenv board_rev EMMC; setenv fdtfile am335x-bonegreen.dtb; fi;
finduuid=part uuid ${devtype} ${bootpart} uuid
fit_bootfile=fitImage
fit_loadaddr=0x90000000
if_netconsole=ping $serverip
importbootenv=echo Importing environment from ${devtype} …; env import -t ${loadaddr} ${filesize}
init_console=if test $board_name = A335_ICE; then setenv console ttyS3,115200n8;elif test $board_name = A335BLGC; then setenv console ttyS4,115200n8;else setenv console ttyS0,115200n8;fi;
ipaddr=192.168.1.2
kernel_addr_r=0x82000000
load_efi_dtb=load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${prefix}${efi_fdtfile}
loadaddr=0x82000000
loadbootenv=load ${devtype} ${bootpart} ${loadaddr} ${bootenvfile}
loadbootscript=load ${devtype} ${bootpart} ${loadaddr} ${scriptfile};
loadfdt=echo loading ${fdtdir}/${fdtfile} …; load ${devtype} ${bootpart} ${fdtaddr} ${fdtdir}/${fdtfile}
loadfit=run args_mmc; bootm ${loadaddr}#${fdtfile};
loadimage=load ${devtype} ${bootpart} ${loadaddr} ${bootdir}/${bootfile}
loadoverlay=echo uboot_overlays: loading ${actual_uboot_overlay} …; load ${devtype} ${bootpart} ${rdaddr} ${actual_uboot_overlay}; fdt addr ${fdtaddr}; fdt resize ${fdt_buffer}; fdt apply ${rdaddr}; fdt resize ${fdt_buffer};
loadramdisk=load mmc ${mmcdev} ${rdaddr} ramdisk.gz
loadrd=load ${devtype} ${bootpart} ${rdaddr} ${bootdir}/${rdfile}; setenv rdsize ${filesize}
mmc_boot=if mmc dev ${devnum}; then devtype=mmc; run scan_dev_for_boot_part; fi
mmcboot=mmc dev ${mmcdev}; setenv devnum ${mmcdev}; setenv devtype mmc; if mmc rescan; then echo SD/MMC found on device ${mmcdev};if run loadimage; then if test ${boot_fit} -eq 1; then run loadfit; else run mmcloados;fi;fi;fi;
mmcdev=0
mmcloados=run args_mmc; if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if run loadfdt; then if test -n ${uname_r}; then bootz ${loadaddr} ${rdaddr}:${rdsize} ${fdtaddr}; else bootz ${loadaddr} - ${fdtaddr}; fi; else if test ${boot_fdt} = try; then bootz; else echo WARN: Cannot load the DT; fi; fi; else bootz; fi;
mmcrootfstype=ext4 rootwait
netargs=setenv bootargs console=${console} ${optargs} root=/dev/nfs nfsroot=${serverip}:${rootpath},${nfsopts} rw ip=dhcp
netboot=echo Booting from network …; setenv autoload no; dhcp; run netloadimage; run netloadfdt; run netargs; bootz ${loadaddr} - ${fdtaddr}
netloadfdt=tftp ${fdtaddr} ${fdtfile}
netloadimage=tftp ${loadaddr} ${bootfile}
nfsopts=nolock
partitions=uuid_disk=${uuid_gpt_disk};name=bootloader,start=384K,size=1792K,uuid=${uuid_gpt_bootloader};name=rootfs,start=2688K,size=-,uuid=${uuid_gpt_rootfs}
pb_eeprom_hdr=mw 82001000 ee3355aa; mw 82001004 35333341; mw 82001008 4c474250
preboot=run if_netconsole start_netconsole
pxefile_addr_r=0x80100000
ramargs=setenv bootargs console=${console} ${optargs} root=${ramroot} rootfstype=${ramrootfstype}
ramboot=echo Booting from ramdisk …; run ramargs; bootz ${loadaddr} ${rdaddr} ${fdtaddr}
ramdisk_addr_r=0x88080000
ramroot=/dev/ram0 rw
ramrootfstype=ext2
rdaddr=0x88080000
rootpath=/export/rootfs
scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}…; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done;run scan_dev_for_efi;
scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} bootfstype; then run scan_dev_for_boot; fi; done; setenv devplist
scan_dev_for_efi=setenv efi_fdtfile ${fdtfile}; if test -z “${fdtfile}” -a -n “${soc}”; then setenv efi_fdtfile ${soc}-${board}${boardver}.dtb; fi; for prefix in ${efi_dtb_prefixes}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${efi_fdtfile}; then run load_efi_dtb; fi;done;if test -e ${devtype} ${devnum}:${distro_bootpart} efi/boot/bootarm.efi; then echo Found EFI removable media binary efi/boot/bootarm.efi; run boot_efi_binary; echo EFI LOAD FAILED: continuing…; fi; setenv efi_fdtfile
scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${boot_syslinux_conf}; then echo Found ${prefix}${boot_syslinux_conf}; run boot_extlinux; echo SCRIPT FAILED: continuing…; fi
scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing…; fi; done
script=boot.scr
scriptaddr=0x80000000
scriptfile=${script}
serial#=2046SBI10516
serverip=192.168.1.1
soc=am33xx
spiargs=setenv bootargs console=${console} ${optargs} root=${spiroot} rootfstype=${spirootfstype}
spiboot=echo Booting from spi …; run spiargs; sf probe ${spibusno}:0; sf read ${loadaddr} ${spisrcaddr} ${spiimgsize}; bootz ${loadaddr}
spibusno=0
spiimgsize=0x362000
spiroot=/dev/mtdblock4 rw
spirootfstype=jffs2
spisrcaddr=0xe0000
start_netconsole=setenv ncip $serverip; setenv bootdelay 10; setenv stdin serial,nc; setenv stdout serial,nc; setenv stderr serial,nc; version
static_ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off
stderr=ns16550_serial
stdin=ns16550_serial
stdout=ns16550_serial
uname_boot=setenv bootdir /boot; setenv bootfile vmlinuz-${uname_r}; if test -e ${devtype} ${bootpart} ${bootdir}/${bootfile}; then echo loading ${bootdir}/${bootfile} …; run loadimage;setenv fdtdir /boot/dtbs/${uname_r}; echo debug: [enable_uboot_overlays=${enable_uboot_overlays}] … ;if test -n ${enable_uboot_overlays}; then echo debug: [enable_uboot_cape_universal=${enable_uboot_cape_universal}] … ;if test -n ${enable_uboot_cape_universal}; then echo debug: [uboot_base_dtb_univ=${uboot_base_dtb_univ}] … ;if test -n ${uboot_base_dtb_univ}; then echo uboot_overlays: [uboot_base_dtb=${uboot_base_dtb_univ}] … ;if test -e ${devtype} ${bootpart} ${fdtdir}/${uboot_base_dtb_univ}; then setenv fdtfile ${uboot_base_dtb_univ};echo uboot_overlays: Switching too: dtb=${fdtfile} …;setenv cape_uboot bone_capemgr.uboot_capemgr_enabled=1; else echo debug: unable to find [${uboot_base_dtb_univ}] using [${uboot_base_dtb}] instead … ;echo debug: [uboot_base_dtb_univ=${uboot_base_dtb}] … ;if test -n ${uboot_base_dtb}; then echo uboot_overlays: [uboot_base_dtb=${uboot_base_dtb}] … ;if test -e ${devtype} ${bootpart} ${fdtdir}/${uboot_base_dtb}; then setenv fdtfile ${uboot_base_dtb};echo uboot_overlays: Switching too: dtb=${fdtfile} …;fi;fi;fi;fi;else echo debug: [uboot_base_dtb_univ=${uboot_base_dtb}] … ;if test -n ${uboot_base_dtb}; then echo uboot_overlays: [uboot_base_dtb=${uboot_base_dtb}] … ;if test -e ${devtype} ${bootpart} ${fdtdir}/${uboot_base_dtb}; then setenv fdtfile ${uboot_base_dtb};echo uboot_overlays: Switching too: dtb=${fdtfile} …;fi;fi;fi;fi;if test -e ${devtype} ${bootpart} ${fdtdir}/${fdtfile}; then run loadfdt;else setenv fdtdir /usr/lib/linux-image-${uname_r}; if test -e ${devtype} ${bootpart} ${fdtdir}/${fdtfile}; then run loadfdt;else setenv fdtdir /lib/firmware/${uname_r}/device-tree; if test -e ${devtype} ${bootpart} ${fdtdir}/${fdtfile}; then run loadfdt;else setenv fdtdir /boot/dtb-${uname_r}; if test -e ${devtype} ${bootpart} ${fdtdir}/${fdtfile}; then run loadfdt;else setenv fdtdir /boot/dtbs; if test -e ${devtype} ${bootpart} ${fdtdir}/${fdtfile}; then run loadfdt;else setenv fdtdir /boot/dtb; if test -e ${devtype} ${bootpart} ${fdtdir}/${fdtfile}; then run loadfdt;else setenv fdtdir /boot; if test -e ${devtype} ${bootpart} ${fdtdir}/${fdtfile}; then run loadfdt;else if test -e ${devtype} ${bootpart} ${fdtfile}; then run loadfdt;else echo; echo unable to find [dtb=${fdtfile}] did you name it correctly? …; run failumsboot;fi;fi;fi;fi;fi;fi;fi;fi; if test -n ${enable_uboot_overlays}; then setenv fdt_buffer 0x60000;if test -n ${uboot_fdt_buffer}; then setenv fdt_buffer ${uboot_fdt_buffer};fi;echo uboot_overlays: [fdt_buffer=${fdt_buffer}] … ;if test -n ${uboot_silicon}; then setenv uboot_overlay ${uboot_silicon}; run virtualloadoverlay;fi;if test -n ${uboot_model}; then setenv uboot_overlay ${uboot_model}; run virtualloadoverlay;fi;if test -n ${disable_uboot_overlay_adc}; then echo uboot_overlays: uboot loading of [BB-ADC-00A0.dtbo] disabled by /boot/uEnv.txt [disable_uboot_overlay_adc=1]…;else setenv uboot_overlay BB-ADC-00A0.dtbo; run virtualloadoverlay;fi;if test -n ${uboot_overlay_addr0}; then if test -n ${disable_uboot_overlay_addr0}; then echo uboot_overlays: uboot loading of [${uboot_overlay_addr0}] disabled by /boot/uEnv.txt [disable_uboot_overlay_addr0=1]…;else setenv uboot_overlay ${uboot_overlay_addr0}; run virtualloadoverlay;fi;fi;if test -n ${uboot_overlay_addr1}; then if test -n ${disable_uboot_overlay_addr1}; then echo uboot_overlays: uboot loading of [${uboot_overlay_addr1}] disabled by /boot/uEnv.txt [disable_uboot_overlay_addr1=1]…;else setenv uboot_overlay ${uboot_overlay_addr1}; run virtualloadoverlay;fi;fi;if test -n ${uboot_overlay_addr2}; then if test -n ${disable_uboot_overlay_addr2}; then echo uboot_overlays: uboot loading of [${uboot_overlay_addr2}] disabled by /boot/uEnv.txt [disable_uboot_overlay_addr2=1]…;else setenv uboot_overlay ${uboot_overlay_addr2}; run virtualloadoverlay;fi;fi;if test -n ${uboot_overlay_addr3}; then if test -n ${disable_uboot_overlay_addr3}; then echo uboot_overlays: uboot loading of [${uboot_overlay_addr3}] disabled by /boot/uEnv.txt [disable_uboot_overlay_addr3=1]…;else setenv uboot_overlay ${uboot_overlay_addr3}; run virtualloadoverlay;fi;fi;if test -n ${uboot_overlay_addr4}; then setenv uboot_overlay ${uboot_overlay_addr4}; run virtualloadoverlay;fi;if test -n ${uboot_overlay_addr5}; then setenv uboot_overlay ${uboot_overlay_addr5}; run virtualloadoverlay;fi;if test -n ${uboot_overlay_addr6}; then setenv uboot_overlay ${uboot_overlay_addr6}; run virtualloadoverlay;fi;if test -n ${uboot_overlay_addr7}; then setenv uboot_overlay ${uboot_overlay_addr7}; run virtualloadoverlay;fi;if test -n ${uboot_emmc}; then if test -n ${disable_uboot_overlay_emmc}; then echo uboot_overlays: uboot loading of [${uboot_emmc}] disabled by /boot/uEnv.txt [disable_uboot_overlay_emmc=1]…;else setenv uboot_overlay ${uboot_emmc}; run virtualloadoverlay;fi;fi;if test -n ${uboot_video}; then if test -n ${disable_uboot_overlay_video}; then echo uboot_overlays: uboot loading of [${uboot_video}] disabled by /boot/uEnv.txt [disable_uboot_overlay_video=1]…;else if test -n ${disable_uboot_overlay_audio}; then echo uboot_overlays: uboot loading of [${uboot_video}] disabled by /boot/uEnv.txt [disable_uboot_overlay_audio=1]…;setenv uboot_overlay ${uboot_video_naudio}; run virtualloadoverlay;else setenv uboot_overlay ${uboot_video}; run virtualloadoverlay;fi;fi;fi;if test -n ${uboot_wireless}; then if test -n ${disable_uboot_overlay_wireless}; then echo uboot_overlays: uboot loading of [${uboot_wireless}] disabled by /boot/uEnv.txt [disable_uboot_overlay_wireless=1]…;else setenv uboot_overlay ${uboot_wireless}; run virtualloadoverlay;fi;fi;if test -n ${uboot_overlay_pru}; then setenv uboot_overlay ${uboot_overlay_pru}; run virtualloadoverlay;fi;if test -n ${uboot_overlay_pru_add}; then setenv uboot_overlay ${uboot_overlay_pru_add}; run virtualloadoverlay;fi;if test -n ${dtb_overlay}; then setenv uboot_overlay ${dtb_overlay}; echo uboot_overlays: [dtb_overlay=${uboot_overlay}] … ;run virtualloadoverlay;fi;else echo uboot_overlays: add [enable_uboot_overlays=1] to /boot/uEnv.txt to enable…;fi;if test -n ${uboot_detected_capes}; then echo uboot_overlays: [uboot_detected_capes=${uboot_detected_capes_addr0}${uboot_detected_capes_addr1}${uboot_detected_capes_addr2}${uboot_detected_capes_addr3}] … ;setenv uboot_detected_capes uboot_detected_capes=${uboot_detected_capes_addr0}${uboot_detected_capes_addr1}${uboot_detected_capes_addr2}${uboot_detected_capes_addr3}; fi;setenv rdfile initrd.img-${uname_r}; if test -e ${devtype} ${bootpart} ${bootdir}/${rdfile}; then echo loading ${bootdir}/${rdfile} …; run loadrd;if test -n ${netinstall_enable}; then run args_netinstall; run message;echo debug: [${bootargs}] … ;echo debug: [bootz ${loadaddr} ${rdaddr}:${rdsize} ${fdtaddr}] … ;bootz ${loadaddr} ${rdaddr}:${rdsize} ${fdtaddr}; fi;if test -n ${uenv_root}; then run args_uenv_root;echo debug: [${bootargs}] … ;echo debug: [bootz ${loadaddr} ${rdaddr}:${rdsize} ${fdtaddr}] … ;bootz ${loadaddr} ${rdaddr}:${rdsize} ${fdtaddr}; fi;if test -n ${uuid}; then run args_mmc_uuid;echo debug: [${bootargs}] … ;echo debug: [bootz ${loadaddr} ${rdaddr}:${rdsize} ${fdtaddr}] … ;bootz ${loadaddr} ${rdaddr}:${rdsize} ${fdtaddr}; fi;run args_mmc_old;echo debug: [${bootargs}] … ;echo debug: [bootz ${loadaddr} ${rdaddr}:${rdsize} ${fdtaddr}] … ;bootz ${loadaddr} ${rdaddr}:${rdsize} ${fdtaddr}; else if test -n ${uenv_root}; then run args_uenv_root;echo debug: [${bootargs}] … ;echo debug: [bootz ${loadaddr} - ${fdtaddr}] … ;bootz ${loadaddr} - ${fdtaddr}; fi;run args_mmc_old;echo debug: [${bootargs}] … ;echo debug: [bootz ${loadaddr} - ${fdtaddr}] … ;bootz ${loadaddr} - ${fdtaddr}; fi;fi;
update_to_fit=setenv loadaddr ${fit_loadaddr}; setenv bootfile ${fit_bootfile}
usb_boot=usb start; if usb dev ${devnum}; then devtype=usb; run scan_dev_for_boot_part; fi
usbnet_devaddr=2c:ab:33:6a:bb:5e
vendor=ti
ver=U-Boot 2019.04-g923f8b8 (Jan 02 2022 - 19:05:15 +0000)
virtualloadoverlay=if test -e ${devtype} ${bootpart} ${fdtdir}/overlays/${uboot_overlay}; then setenv actual_uboot_overlay ${fdtdir}/overlays/${uboot_overlay}; run loadoverlay;else if test -e ${devtype} ${bootpart} /lib/firmware/${uboot_overlay}; then setenv actual_uboot_overlay /lib/firmware/${uboot_overlay}; run loadoverlay;else if test -e ${devtype} ${bootpart} ${uboot_overlay}; then setenv actual_uboot_overlay ${uboot_overlay}; run loadoverlay;else echo uboot_overlays: unable to find [${devtype} ${bootpart} ${uboot_overlay}]…;fi;fi;fi;
Environment size: 25272/131068 bytes
