I have been using a Raspberry Pi as a terminal for my BeagleBone Black so I don’t need two keyboards and mice. I connect using
ssh -X debian@192.168.0.24
Just recently this has stopped working with a “signature incorrect” message. I’ve googled and tried more things than I can remember and it still doesn’t work. Both the Raspberry Pi and the BeagleBone Black are running the same version of OpenSSH 7.4p1-10. As far as I can tell, /etc/ssh/sshd_config is the same for both.
I can ssh -X into the Raspberry Pi, but not the BeagleBone Black from my Mac. I am also unable to ssh from the BeagleBone Black to the Raspberry Pi.
The -vvv output on my Mac is:
ssh -vvv -o HostKeyAlgorithms=ssh-rsa -X debian@192.168.0.24
OpenSSH_6.2p2, OSSLShim 0.9.8r 8 Dec 2011
debug1: Reading configuration data /Users/brent/.ssh/config
debug1: /Users/brent/.ssh/config line 5: Applying options for 192.168.0.*
debug1: Reading configuration data /etc/ssh_config
debug1: /etc/ssh_config line 20: Applying options for *
debug1: /etc/ssh_config line 102: Applying options for *
debug2: ssh_connect: needpriv 0
debug1: Connecting to 192.168.0.24 [192.168.0.24] port 22.
debug1: Connection established.
debug3: Incorrect RSA1 identifier
debug3: Could not load “/Users/brent/.ssh/id_rsa” as a RSA1 public key
debug1: identity file /Users/brent/.ssh/id_rsa type 1
debug1: identity file /Users/brent/.ssh/id_rsa-cert type -1
debug1: identity file /Users/brent/.ssh/id_dsa type -1
debug1: identity file /Users/brent/.ssh/id_dsa-cert type -1
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_6.2
debug1: Remote protocol version 2.0, remote software version OpenSSH_7.4p1 Debian-10+deb9u4
debug1: match: OpenSSH_7.4p1 Debian-10+deb9u4 pat OpenSSH*
debug2: fd 3 setting O_NONBLOCK
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug2: kex_parse_kexinit: diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1
debug2: kex_parse_kexinit: ssh-rsa
debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour128,aes128-gcm@openssh.com,aes256-gcm@openssh.com,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,rijndael-cbc@lysator.liu.se
debug2: kex_parse_kexinit: hmac-md5-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-ripemd160-etm@openssh.com,hmac-sha1-96-etm@openssh.com,hmac-md5-96-etm@openssh.com,hmac-md5,hmac-sha1,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96
debug2: kex_parse_kexinit: none,zlib@openssh.com,zlib
debug2: kex_parse_kexinit: first_kex_follows 0
debug2: kex_parse_kexinit: reserved 0
debug2: kex_parse_kexinit: curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group14-sha256,diffie-hellman-group14-sha1
debug2: kex_parse_kexinit: ssh-rsa,rsa-sha2-512,rsa-sha2-256,ssh-ed25519
debug2: kex_parse_kexinit: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com
debug2: kex_parse_kexinit: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: mac_setup: found hmac-sha1-etm@openssh.com
debug1: kex: server->client aes128-ctr hmac-sha1-etm@openssh.com none
debug1: kex: client->server aes128-ctr hmac-sha1-etm@openssh.com none
debug1: SSH2_MSG_KEX_DH_GEX_REQUEST(1024<2048<8192) sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_GROUP
debug2: dh_gen_key: priv key bits set: 153/320
debug2: bits set: 1030/2048
debug1: SSH2_MSG_KEX_DH_GEX_INIT sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_REPLY
debug1: Server host key: RSA d9:f7:38:5a:96:42:fa:cb:df:2b:fd:af:9b:ee:31:32
debug3: load_hostkeys: loading entries for host “192.168.0.24” from file “/dev/null”
debug3: load_hostkeys: loaded 0 keys
Warning: Permanently added ‘192.168.0.24’ (RSA) to the list of known hosts.
debug2: bits set: 1033/2048
RSA_public_decrypt failed: unknown err
debug1: ssh_rsa_verify: signature incorrect
key_verify failed for server_host_key
Any help would be greatly appreciated. I am at my wit’s end.
thanks,
brent
