I formated my MMC/SD Card for FAT32 File System and
copied MLO, u-boot.bin, u-boot-f.bin, ramdisk.gz, uImage.bin,
boot.scr, x-load.bin.ift, normal.scr onto MMC in the same order as the
names given. Then I inserted the SD card into SD slot on the Beagle
Board, but in the terminal am getting like this
Texas Instruments X-Loader 1.4.2 (Feb 19 2009 - 12:01:24)
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2009.06-rc2 (Jun 05 2009 - 10:19:13)
OMAP3530-GP ES3.0, CPU-OPP2 L3-165MHz
DRAM: 256 MB
NAND: 256 MiB
*** Warning - bad CRC or NAND, using default environment
In: serial
Out: serial
Err: serial
Board revision C
Die ID #66e000030000000004013f790401c010
OMAP3 beagleboard.org #
Reading boot sector
DRAM: 256 MB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
Board revision C
mmc1 is available
reading boot.scr
4077 bytes read
Running bootscript from mmc ...
## Executing script at 82000000
Wrong image format for "source" command
Does anyone has a solution for this?
Raghunath
