I follow instruction in http://elinux.org/BeagleBoardAndOpenEmbeddedGit.
but there is a error.
my host Pc is ubuntu 8.04
and BB is mojo hasty-armv5el wind 2.6.28 version kernel.
How can I fix it?
How can I fix it?
Check you local.conf configuration file, probably this line.
BB_NUMBER_THREADS = "2"
Make sure you have quotes
Thanks ..
but I found other errors.
there are no files in /home/asdf/oe/openembedded/packages/zlib/zlib-
native*
I checked out from svn but zlib-native* files did not exist.
how can I solve this problem?
Thanks for your help.
NOTE: Out of date cache found, rebuilding...
NOTE: Handling BitBake files: / (6403/6403) [100 %]
NOTE: Parsing finished. 0 cached, 6122 parsed, 281 skipped, 0 masked.
NOTE: build 200901211013: started
OE Build Configuration:
BB_VERSION = "1.8.13"
METADATA_BRANCH = "org.openembedded.dev"
METADATA_REVISION = "6fcdfe2e646bb525b137c286f47a1ce48d94dcbc"
TARGET_ARCH = "arm"
TARGET_OS = "linux-gnueabi"
MACHINE = "beagleboard"
DISTRO = "angstrom"
DISTRO_VERSION = "2009.X-test-20090121"
TARGET_FPU = "hard"
NOTE: Resolving any missing task queue dependencies
NOTE: preferred version git of u-boot not available (for item u-boot)
NOTE: Preparing runqueue
NOTE: Executing runqueue
NOTE: Running task 168 of 2224 (ID: 1372, /home/asdf/oe/openembedded/
packages/glibc/glibc-initial_2.6.1.bb, do_install)
NOTE: package glibc-initial-2.6.1: started
NOTE: Running task 199 of 2224 (ID: 673, /home/asdf/oe/openembedded/
packages/zlib/zlib-native_1.2.3.bb, do_fetch)
NOTE: package glibc-initial-2.6.1-r15: task do_install: started
NOTE: package zlib-native-1.2.3: started
NOTE: package zlib-native-1.2.3-r5: task do_fetch: started
NOTE: package glibc-initial-2.6.1-r15: task do_install: completed
NOTE: package glibc-initial-2.6.1: completed
NOTE: The MD5Sums did not match. Wanted:
'dee233bf288ee795ac96a98cc2e369b6' and Got:
'131dbea38f50e2ef532ce5e1dc8ecc11'
NOTE: Running task 200 of 2224 (ID: 1373, /home/asdf/oe/openembedded/
packages/glibc/glibc-initial_2.6.1.bb, do_populate_staging)
NOTE: Task failed: Checksum of 'http://www.zlib.net/
zlib-1.2.3.tar.bz2' failed
NOTE: package zlib-native-1.2.3-r5: task do_fetch: failed
ERROR: TaskFailed event exception, aborting
NOTE: package zlib-native-1.2.3: failed
ERROR: Build of /home/asdf/oe/openembedded/packages/zlib/zlib-
native_1.2.3.bb do_fetch failed
NOTE: package glibc-initial-2.6.1-r15: task do_populate_staging:
started
ERROR: Task 673 (_1.2.3.bb, do_fetch) failed
NOTE: Waiting for 1 active tasks to finish
NOTE: 1: /home/asdf/oe/openembedded/packages/glibc/glibc-
initial_2.6.1.bb, do_populate_staging (13058)
completed
NOTE: Tasks Summary: Attempted 198 tasks of which 197 didn't need to
be rerun and 1 failed.
ERROR: '/home/asdf/oe/openembedded/packages/zlib/zlib-native_1.2.3.bb'
failed
NOTE: build 200901211013: completed
2009/1/20 나몰라 <ssm3722@gmail.com>
Thanks …
native*
how can I solve this problem?Thanks for your help.
NOTE: Out of date cache found, rebuilding…
NOTE: build 200901211013: startedOE Build Configuration:
BB_VERSION = “1.8.13”
METADATA_BRANCH = “org.openembedded.dev”
METADATA_REVISION = “6fcdfe2e646bb525b137c286f47a1ce48d94dcbc”
TARGET_ARCH = “arm”
TARGET_OS = “linux-gnueabi”
MACHINE = “beagleboard”
DISTRO = “angstrom”
DISTRO_VERSION = “2009.X-test-20090121”
TARGET_FPU = “hard”NOTE: Resolving any missing task queue dependencies
‘dee233bf288ee795ac96a98cc2e369b6’ and Got:
‘131dbea38f50e2ef532ce5e1dc8ecc11’
NOTE: Task failed: Checksum of ‘http://www.zlib.net/
zlib-1.2.3.tar.bz2’ failed
started
completed
NOTE: Tasks Summary: Attempted 198 tasks of which 197 didn’t need to
ERROR: ‘/home/asdf/oe/openembedded/packages/zlib/zlib-native_1.2.3.bb’
failed
I ran into similar problems (with checksums not matching), and discovered it was because I had a partial download of one of the packages that I had to remove. I think it was in oe/tmp/download. I looked for the failing package, removed the .tar.bz2 or .tar.gz file for it, and (usually) there was a .tar.gz.1 or .tar.bz2.1 file there that was the full package. I renamed it (to remove the trailing .1), and restarted bitbake, at which point it worked.
I’m not sure why the system doesn’t automatically remove the incomplete package source when it downloads a new copy, but I’m still new to bitbake.
Brett
but my /tmp/down load they is no .tar.gz.1 or .tar.bz2.1
file.
and I re downloading all file exist.
native_1.2.3.bb do_fetch failed . => I didn't understand this error.
I have another question.
my beagleboard installed ubuntu. Is It passable using openembedded?
elinux.org has oponembedded tutorial only Angstom based.
thanks for your help....
