Hello All;
I seem to have narrowed my previous problems with NMAP to a configure error.
There is either a typo in the config file somewhere or there is a compatibility problem with the latest version of
GCC. The version on the Angstrom image I am using is: “gcc version 4.7.3 20130205 (prerelease) (Linaro GCC 4.7-2013.02-01)”
There appears to be an uppercase “-V” where there should be a lowercase one.
The code below fails:
configure:2854: $? = 0
configure:2843: gcc -V >&5 ß Error
gcc: error: unrecognized command line option ‘-V’
gcc: fatal error: no input files
compilation terminated.
Where a previous commands worked:
configure:2843: gcc -v >&5 ß Works
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/libexec/gcc/arm-angstrom-linux-gnueabi/4.7.3/lto-wrapper
Target: arm-angstrom-linux-gnueabi
Configured with: /build/v2012.12/build/tmp-angstrom_v2012_12-eglibc/work-shared/gcc-linaro-4.7-r9 ………
Can anybody help me with this? I can’t find the config file that contains the error.
Thanks;
Bill
