A float is just 4 bytes of binary data that is coded to show the decimal point position and the number before and after the point. The trick is that you have to tell the C++ compiler that you are not making a stupid mistake and really do want to treat the float as an array of bytes:
void send_float (float f)
// Cast float to a pointer to bytes - Tells C++ you really mean to do that.
byte* bytes = (byte*)&f;
// write the data to the serial
Serial.write (bytes, sizeof(f));
