I have an assembly code(using clpru) that is reading using ECAP a signal meanwhile is generating DShot outputs (both are RC protocols).
The code is running perfectly on beaglebone black, meanwhile the ecap readings are erratic as follow - Erratic Behavior - YouTube
Any clue of what can cause this difference ? I have a similar code - but using pasm and reading the ecap and generating pwm signals working on both beagles.
on the video, the sliders should be changing one slider at time, but using on pocketbeagle, all sliders are changing at same time.
I’m loading the code directly from memory and pru control registers.
both are with kernel 5.10 - black and pocket.
Pasm is not supported by ti, and all pasm code should be migrate to clpru so that is the reason we are migrating.
could you please help me understanding one thing.
I was testing with 5.10-ti kernel and I was having this problem with ecap reading.
Downgrading to 4.19 ti kernel, the code is working. There is any relation between how PRU deal with the code in different kernels ?
One difference, the P2_18 pin in kernel 4.19 is configured as ecap meanwhile in 5.10 is ecap_pwm, this can throw this problem I’m having ?
