The angstrom image that shipped with the BB-XM works flawlessly. But
it is ram based.
So I go to Narcissus on www.angstrom-distribution.org/narcissus/ to
build a image. The image I build is: BeagleBoard-Simple-Console.
After a valid build I load the image and rootfs with the files and try
to boot. It appears to colapse at "udev" and it is very, very
inconsistent. Boot 10 times and it fails 10 different ways.
After I login and run "opkg update" it will start and download one or
two then lock up. I get a lot of "Segmentation failure" errors. Most
of the time I will get an ipaddress, some of the time I won't.
Maybe I need to issue some commands to U-Boot, but I have no idea on
what those should be.
Here is one example of a boot sequence:
Please help.
