I’m working with an X15, and the fan is driving me crazy.
I’m using the recommended heatsink and fan from Digi-Key (the 5V F251R: https://www.digikey.com/products/en?keywords=X15FANKIT-ND ). The fan works, but it constantly turns on and off on what seems to be a completely random basis. Has no relationship with actual CPU load, either.
I’m delving into Debian’s fan control package, lm-sensors, and I’ve found this:
sensors
…which outputs this:
gpio_fan-isa-0000
Adapter: ISA adapter
fan1: 0 RPM (min = 0 RPM, max = 13000 RPM)
tmp102-i2c-0-48
Adapter: OMAP I2C adapter
temp1: +41.4°C (high = +160.0°C, hyst = +150.0°C)
That’s certainly informative, but those set points are insane: I don’t want it getting anywhere near 160°C, or even 150°C for that matter. I presume that someone was aiming for Fahrenheit values. These settings also indicate a problem: if tmp102-i2c-0-48 were actually controlling the fan, it would never turn on - it would probably be fried long before it hit either of those values.
The settings command allows me to query both devices for settable properties:
gpio_fan-isa-0000
fan1:
fan1_input: 13000.000
fan1_min: 0.000
fan1_max: 13000.000
tmp102-i2c-0-48
temp1:
temp1_input: 42.375
temp1_max: 160.000
temp1_max_hyst: 150.000
And I can also change them by creating /etc/sensors.d/x15-config with the following:
chip “tmp102*”
set temp1_max 41
set temp1_max_hyst 39
After either running “sensors -s” to reload settings or just rebooting, the sensors -u command shows that tmp102-i2c has accepted the override values. Unfortunately, it doesn’t affect the annoying fan behavior one bit. Reported CPU temperature is over 41, so it should run constantly until it’s under 39… no dice. Same behavior.
At this point, I can’t figure out what is actually controlling the fan, especially not in this manner. I’m ready to chalk it up to either a flaky fan or a faulty GPIO or… something.
Anyone have any ideas?
