I tried both the solutions… nand erase 260000 20000 results in the recovery but it hangs again at the same point. I am pasting the log that i get and where it gets stuck.
Starting kernel …
[ 0.000000] Linux version 2.6.29-omap1 (islate@islate-desktop) (gcc version 4.3.1 (GCC) ) #1 PREEMPT Mon Jul 26 19:37:06 EDT 2010
[ 0.000000] CPU: ARMv7 Processor [411fc083] revision 3 (ARMv7), cr=10c5387f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: OMAP3 Beagle Board
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] OMAP3430 ES3.1
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xd7000000 size: 0x100000
[ 0.000000] Reserving 14680064 bytes SDRAM for VRAM
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
[ 0.000000] Kernel command line: console=ttyS2,115200n8 video=omapfb:vram:2M,vram:4M,mode:1024x768@60,vxres=1024,vyres=768 root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait
[ 0.000000] Clocking rate (Crystal/DPLL/ARM core): 26.0/166/500 MHz
[ 0.000000] GPMC revision 5.0
[ 0.000000] IRQ: Found an INTC at 0xd8200000 (revision 4.0) with 96 interrupts
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] OMAP34xx GPIO hardware version 2.5
[ 0.000000] PID hash table entries: 1024 (order: 10, 4096 bytes)
[ 0.000000] OMAP clockevent source: GPTIMER12 at 32768 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 128MB 128MB = 256MB total
[ 0.000000] Memory: 238848KB available (5632K code, 576K data, 204K init)
[ 0.000000] Calibrating delay loop… 511.52 BogoMIPS (lpj=1998848)
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] net_namespace: 1036 bytes
[ 0.000000] regulator: core version 0.5
[ 0.000000] NET: Registered protocol family 16
[ 0.000000] GPIO-156 autorequested
[ 0.000000] GPIO-159 autorequested
[ 0.000000] Found NAND on CS0
[ 0.000000] Registering NAND on CS0
[ 53.036407] OMAP DMA hardware revision 4.0
[ 53.082977] bio: create slab at 0
[ 53.146514] OMAP DSS rev 2.0
[ 53.146636] OMAP DISPC rev 3.0
[ 53.146667] OMAP VENC rev 2
[ 53.146850] OMAP DSI rev 1.0
[ 53.149993] i2c_omap i2c_omap.1: bus 1 rev3.12 at 2600 kHz
[ 53.154083] twl4030: PIH (irq 7) chaining IRQs 368…375
[ 53.154113] twl4030: power (irq 373) chaining IRQs 376…383
[ 53.154754] twl4030: gpio (irq 368) chaining IRQs 384…401
[ 53.157928] regulator: VMMC1: 1850 <–> 3150 mV normal standby
[ 53.158905] regulator: VDAC: 1800 mV normal standby
[ 53.159851] regulator: VUSB1V5: 1500 <–> 0 mV normal standby
[ 53.160797] regulator: VUSB1V8: 1800 <–> 0 mV normal standby
[ 53.161743] regulator: VUSB3V1: 3100 <–> 0 mV normal standby
[ 53.162750] regulator: VPLL2: 1800 mV normal standby
[ 53.163726] regulator: VMMC2: 2800 <–> 3150 mV normal standby
[ 53.164703] regulator: VSIM: 1800 <–> 3000 mV normal standby
[ 53.178527] i2c_omap i2c_omap.2: bus 2 rev3.12 at 400 kHz
[ 53.194519] i2c_omap i2c_omap.3: bus 3 rev3.12 at 100 kHz
[ 53.196746] SCSI subsystem initialized
[ 53.200561] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[ 53.202239] usbcore: registered new interface driver usbfs
[ 53.203002] usbcore: registered new interface driver hub
[ 53.203491] usbcore: registered new device driver usb
[ 53.206848] Bluetooth: Core ver 2.14
[ 53.207427] NET: Registered protocol family 31
[ 53.207427] Bluetooth: HCI device and connection manager initialized
[ 53.207458] Bluetooth: HCI socket layer initialized
[ 53.208251] cfg80211: Using static regulatory domain info
[ 53.208282] cfg80211: Regulatory domain: US
[ 53.208312] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 53.208312] (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
[ 53.208343] (5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 53.208374] (5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 53.208374] (5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 53.208404] (5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 53.208435] (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
[ 53.208465] cfg80211: Calling CRDA for country: US
[ 53.212554] musb_hdrc: version 6.0, musb-dma, otg (peripheral+host), debug=0
[ 53.215301] musb_hdrc: USB OTG mode controller at d80ab000 using DMA, IRQ 92
[ 53.216644] NET: Registered protocol family 2
[ 53.216918] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 53.217590] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 53.217864] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[ 53.217987] TCP: Hash tables configured (established 8192 bind 8192)
[ 53.218017] TCP reno registered
[ 53.218322] NET: Registered protocol family 1
[ 53.222991] VFS: Disk quotas dquot_6.5.2
[ 53.223114] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 53.223785] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 53.224578] JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 53.225585] msgmni has been set to 466
[ 53.230743] alg: No test for stdrng (krng)
[ 53.230865] io scheduler noop registered
[ 53.230865] io scheduler anticipatory registered
[ 53.230895] io scheduler deadline registered
[ 53.231109] io scheduler cfq registered (default)
[ 53.257904] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 53.281433] serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654
[ 53.303894] serial8250.0: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654
[ 53.325531] serial8250.0: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654
[ 53.325592] console [ttyS2] enabled
[ 53.857360] brd: module loaded
[ 53.867187] loop: module loaded
[ 53.871124] enc28j60 spi4.0: enc28j60 Ethernet driver 1.01 loaded
[ 53.879974] enc28j60 spi4.0: enc28j60 chip not found
[ 53.885192] enc28j60: probe of spi4.0 failed with error -5
[ 53.891845] usbcore: registered new interface driver catc
[ 53.897277] catc: v2.8:CATC EL1210A NetMate USB Ethernet driver
[ 53.903686] usbcore: registered new interface driver kaweth
[ 53.909332] pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB Ethernet driver
[ 53.917236] usbcore: registered new interface driver pegasus
[ 53.922973] rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet driver
[ 53.930267] usbcore: registered new interface driver rtl8150
[ 53.936248] usbcore: registered new interface driver asix
[ 53.942016] usbcore: registered new interface driver cdc_ether
[ 53.948242] usbcore: registered new interface driver dm9601
[ 53.954223] usbcore: registered new interface driver smsc95xx
[ 53.960296] usbcore: registered new interface driver gl620a
[ 53.966308] usbcore: registered new interface driver net1080
[ 53.972351] usbcore: registered new interface driver plusb
[ 53.978240] usbcore: registered new interface driver rndis_host
[ 53.984527] usbcore: registered new interface driver cdc_subset
[ 53.990783] usbcore: registered new interface driver zaurus
[ 53.996765] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 54.004608] Broadcom 43xx driver loaded [ Features: L, Firmware-ID: FW13 ]
[ 54.012023] usbcore: registered new interface driver zd1211rw
[ 54.018188] usbcore: registered new interface driver rtl8187
[ 54.024291] usbcore: registered new interface driver rndis_wlan
[ 54.030548] usbcore: registered new interface driver zd1201
[ 54.036560] usbcore: registered new interface driver usb8xxx
[ 54.042663] usbcore: registered new interface driver rt2500usb
[ 54.048919] usbcore: registered new interface driver rt73usb
[ 54.055023] usbcore: registered new interface driver p54usb
[ 54.060638] i2c /dev entries driver
[ 54.066284] Driver ‘sd’ needs updating - please use bus_type methods
[ 54.073059] Driver ‘sr’ needs updating - please use bus_type methods
[ 54.080688] omap2-nand driver initializing
[ 54.085113] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba (Micron NAND 256MiB 1,8V 16-bit)
[ 54.094238] cmdlinepart partition parsing not available
[ 54.099517] Creating 5 MTD partitions on “omap2-nand”:
[ 54.104736] 0x000000000000-0x000000080000 : “X-Loader”
[ 54.112304] 0x000000080000-0x000000260000 : “U-Boot”
[ 54.119598] 0x000000260000-0x000000280000 : “U-Boot Env”
[ 54.126525] 0x000000280000-0x000000680000 : “Kernel”
[ 54.134643] 0x000000680000-0x000010000000 : “File System”
[ 54.252502] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 54.259582] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 54.266326] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
[ 54.274200] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 54.288909] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 54.295562] usb usb1: configuration #1 chosen from 1 choice
[ 54.301849] hub 1-0:1.0: USB hub found
[ 54.305755] hub 1-0:1.0: 3 ports detected
[ 54.312194] Initializing USB Mass Storage driver…
[ 54.317626] usbcore: registered new interface driver usb-storage
[ 54.323730] USB Mass Storage support registered.
[ 54.329254] mice: PS/2 mouse device common for all mice
[ 54.335205] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 54.344940] input: twl4030_pwrbutton as /devices/platform/i2c_omap.1/i2c-adapter/i2c-1/1-0049/twl4030_pwrbutton/input/input1
[ 55.362487] i2c_omap i2c_omap.2: controller timed out
[ 55.367675] rtc-ds1307: probe of 2-0068 failed with error -5
[ 55.375457] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 55.381805] Bluetooth: HCI UART driver ver 2.2
[ 55.386322] Bluetooth: HCI H4 protocol initialized
[ 55.391235] Bluetooth: HCI BCSP protocol initialized
[ 55.396209] Bluetooth: HCILL protocol initialized
[ 55.401000] Bluetooth: Broadcom Blutonium firmware driver ver 1.2
[ 55.407531] usbcore: registered new interface driver bcm203x
[ 55.413238] Bluetooth: Digianswer Bluetooth USB driver ver 0.10
[ 55.419555] usbcore: registered new interface driver bpa10x
[ 55.425262] Bluetooth: BlueFRITZ! USB driver ver 1.2
[ 55.430603] usbcore: registered new interface driver bfusb
[ 55.436157] Bluetooth: Generic Bluetooth USB driver ver 0.4
[ 55.442138] usbcore: registered new interface driver btusb
[ 55.447723] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[ 55.454681] mmci-omap-hs mmci-omap-hs.0: Failed to get debounce clock
[ 55.570312] mmci-omap-hs mmci-omap-hs.1: Failed to get debounce clock
[ 55.576904] regulator: Unable to get requested regulator: vmmc_aux
[ 55.594177] Registered led device: beagleboard::usr0
[ 55.599578] Registered led device: beagleboard::usr1
[ 55.612640] usbcore: registered new interface driver usbhid
[ 55.618377] usbhid: v2.6:USB HID core driver
[ 55.624023] Advanced Linux Sound Architecture Driver Version 1.0.18a.
[ 55.631530] usbcore: registered new interface driver snd-usb-audio
[ 55.638427] No device for DAI twl4030
[ 55.642333] No device for DAI omap-mcbsp-dai-0
[ 55.646789] No device for DAI omap-mcbsp-dai-1
[ 55.651336] No device for DAI omap-mcbsp-dai-2
[ 55.655822] No device for DAI omap-mcbsp-dai-3
[ 55.660308] No device for DAI omap-mcbsp-dai-4
[ 55.664825] OMAP3 Beagle SoC init
[ 55.668670] TWL4030 Audio Codec init
[ 55.673980] asoc: twl4030 <-> omap-mcbsp-dai-0 mapping ok
[ 55.690338] ALSA device list:
[ 55.693359] #0: omap3beagle (twl4030)
[ 55.697875] oprofile: using arm/armv7
[ 55.701843] TCP cubic registered
[ 55.705169] NET: Registered protocol family 17
[ 55.709686] NET: Registered protocol family 15
[ 55.714324] Bluetooth: L2CAP ver 2.11
[ 55.718017] Bluetooth: L2CAP socket layer initialized
[ 55.723144] Bluetooth: SCO (Voice Link) ver 0.6
[ 55.727752] Bluetooth: SCO socket layer initialized
[ 55.732849] Bluetooth: RFCOMM socket layer initialized
[ 55.738098] Bluetooth: RFCOMM TTY layer initialized
[ 55.743103] Bluetooth: RFCOMM ver 1.10
[ 55.746887] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 55.752258] Bluetooth: BNEP filters: protocol multicast
[ 55.757537] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 55.764587] RPC: Registered udp transport module.
[ 55.769378] RPC: Registered tcp transport module.
[ 55.774230] lib80211: common routines for IEEE802.11 drivers
[ 55.779998] ThumbEE CPU extension supported.
[ 55.784332] Power Management for TI OMAP3.
[ 55.797760] Disabling unused clock “sr2_fck”
[ 55.802062] Disabling unused clock “sr1_fck”
[ 55.806427] Disabling unused clock “mcbsp_fck”
[ 55.810913] Disabling unused clock “mcbsp_fck”
[ 55.815399] Disabling unused clock “mcbsp_fck”
[ 55.819885] Disabling unused clock “mcbsp_ick”
[ 55.824401] Disabling unused clock “mcbsp_ick”
[ 55.828887] Disabling unused clock “mcbsp_ick”
[ 55.833374] Disabling unused clock “gpt2_ick”
[ 55.837799] Disabling unused clock “gpt3_ick”
[ 55.842193] Disabling unused clock “gpt4_ick”
[ 55.846588] Disabling unused clock “gpt5_ick”
[ 55.850982] Disabling unused clock “gpt6_ick”
[ 55.855407] Disabling unused clock “gpt7_ick”
[ 55.859832] Disabling unused clock “gpt8_ick”
[ 55.864196] Disabling unused clock “gpt9_ick”
[ 55.868621] Disabling unused clock “wdt3_ick”
[ 55.873016] Disabling unused clock “wdt3_fck”
[ 55.877441] Disabling unused clock “gpio2_dbck”
[ 55.881988] Disabling unused clock “gpio3_dbck”
[ 55.886596] Disabling unused clock “gpio4_dbck”
[ 55.891174] Disabling unused clock “gpio5_dbck”
[ 55.895751] Disabling unused clock “gpio6_dbck”
[ 55.900329] Disabling unused clock “gpt9_fck”
[ 55.904724] Disabling unused clock “gpt8_fck”
[ 55.909149] Disabling unused clock “gpt7_fck”
[ 55.913513] Disabling unused clock “gpt6_fck”
[ 55.917938] Disabling unused clock “gpt5_fck”
[ 55.922363] Disabling unused clock “gpt4_fck”
[ 55.926757] Disabling unused clock “gpt3_fck”
[ 55.931182] Disabling unused clock “gpt2_fck”
[ 55.935546] Disabling unused clock “gpt1_ick”
[ 55.939971] Disabling unused clock “wdt1_ick”
[ 55.944366] Disabling unused clock “wdt2_ick”
[ 55.948791] Disabling unused clock “wdt2_fck”
[ 55.953186] Disabling unused clock “gpio1_dbck”
[ 55.957763] Disabling unused clock “gpt1_fck”
[ 55.962188] Disabling unused clock “cam_ick”
[ 55.966522] Disabling unused clock “cam_mclk”
[ 55.970947] Disabling unused clock “des1_ick”
[ 55.975341] Disabling unused clock “sha11_ick”
[ 55.979858] Disabling unused clock “rng_ick”
[ 55.984191] Disabling unused clock “aes1_ick”
[ 55.988555] Disabling unused clock “ssi_ick”
[ 55.992889] Disabling unused clock “mailboxes_ick”
[ 55.997711] Disabling unused clock “mcbsp_ick”
[ 56.002227] Disabling unused clock “mcbsp_ick”
[ 56.006683] Disabling unused clock “gpt10_ick”
[ 56.011199] Disabling unused clock “gpt11_ick”
[ 56.015716] Disabling unused clock “hdq_ick”
[ 56.020019] Disabling unused clock “mspro_ick”
[ 56.024505] Disabling unused clock “des2_ick”
[ 56.028900] Disabling unused clock “sha12_ick”
[ 56.033416] Disabling unused clock “aes2_ick”
[ 56.037780] Disabling unused clock “icr_ick”
[ 56.042114] Disabling unused clock “pka_ick”
[ 56.046417] Disabling unused clock “ssi_ssr_fck”
[ 56.051086] Disabling unused clock “hdq_fck”
[ 56.055450] Disabling unused clock “mcbsp_fck”
[ 56.059906] Disabling unused clock “mcbsp_fck”
[ 56.064422] Disabling unused clock “mspro_fck”
[ 56.068908] Disabling unused clock “gpt11_fck”
[ 56.073394] Disabling unused clock “gpt10_fck”
[ 56.077911] Disabling unused clock “dpll4_m6x2_ck”
[ 56.082733] Disabling unused clock “dpll3_m3x2_ck”
[ 56.087585] Disabling unused clock “sys_clkout1”
[ 56.092285] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 1
[ 56.102325] registered taskstats version 1
[ 56.126708] Console: switching to colour frame buffer device 80x30
[ 56.143890] clock: clksel_round_rate_div: dpll4_m4_ck target_rate 48000000
[ 56.150817] clock: new_div = 9, new_rate = 48000000
[ 56.162597] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[ 56.169433] Waiting for root device /dev/mmcblk0p2…
Still gets stuck there !!
