Problems with OpenCV on Angstrom 2012.05
Hey guys,
I have Angstrom 2012.05 running on my Beaglebone. It appears opencv is already installed on it version 2.3 I think. I wrote a script to compile my code with:
#adjust path to source code
cd /home/root/opencv
PKG_CONFIG_PATH=/usr/lib:${PKG_CONFIG_PATH}
export PKG_CONFIG_PATH
pkg-config --cflags opencv
echo ’ ’
pkg-config --libs opencv
echo ’ ’
#adjust name of output file and code file
gcc pkg-config --cflags opencv pkg-config --libs opencv -o tes2 tes2.c
When I run it the output is:
-I/usr/include/opencv
-lopencv_core -lopencv_imgproc -lopencv_highgui -lopencv_ml -lopencv_video -lope
ncv_features2d -lopencv_calib3d -lopencv_objdetect -lopencv_contrib -lopencv_leg
acy -lopencv_flann
/usr/lib/gcc/arm-angstrom-linux-gnueabi/4.5.4/…/…/…/…/arm-angstrom-linux-gnu
eabi/bin/ld: /tmp/cccM3Ktd.o: undefined reference to symbol ‘lrint@@GLIBC_2.4’
eabi/bin/ld: note: ‘lrint@@GLIBC_2.4’ is defined in DSO /lib/libm.so.6 so try ad
ding it to the linker command line
/lib/libm.so.6: could not read symbols: Invalid operation
collect2: ld returned 1 exit status
I tried re installing opencv with opkg it gets 2.4 but it doesn’t delete the old version of opencv and when I ran my script I get more errors where the files seem to clash.
Has anyone got this working? Is my approach correct? Any help would be appreciated.
Try adding '-lm' to the linker cmdline
Where exactly do I put -lm? I keep getting -lm command not found.
did you get the solution? I have similar issues of undefined references.
After playing around for awhile I got it to work with this:
cd /home/root/files
PKG_CONFIG_PATH=/usr/lib/pkgconfig:${PKG_CONFIG_PATH}
gcc $(pkg-config --cflags --libs opencv) -lm -o image image.c
