hi,
As I want to see the Profiling information of a program while running
in Board, so how can I measure this.
hi,
port gprof?
Frans Meulenbroeks <fransmeulenbroeks@gmail.com> writes:
Does it work now? Has Siarhei patch to workaround an errata been
accepted (or even proposed :)?
Laurent
2009/5/14 Måns Rullgård:
port gprof?
oprofile is much better.
Does it work now?
Yes, for those who know how to use it And at the very least, it
works reliably in a standard timer mode.
Has Siarhei patch to workaround an errata been accepted (or even proposed :)?
There are several possible ways to improve oprofile usability on beagleboard.
One of them is to use a timer with much better samples commection
frequency than the 'standard' one. This can be accomplished either by
- using one of GPTIMER's (there are plenty of them in OMAP) for that,
it is simple, low overhead and robust.
- using generic high resolution timer framework from linux kernel,
that's probably a right solution from the architecture point of view,
but it has no practical advantages over GPTIMER one
Another solution is to workaround Cortex-A8 PMU errata and still use
performance monitoring counters. Experimental patch for that was
posted in this mailing list (not to linux-omap yet), but honestly I
did not get any kind of feedback regarding it at all. And more
importantly, I find myself to be quite satisfied with the GPTIMER
based driver
I generally prefer practical solutions which actually work and are
used by people, this gives a bit more confidence when submitting
patches If there is enough interest in having usable oprofile for
beagleboard and OMAP3 based boards/devices, the problem will get
solved itself and all the patches will reach mainline kernel
eventually.
The first step to improve the current situation would be to submit a
patch to add a kernel config option to disable broken ARMv7 PMU based
driver so that at least it does not override the standard timer
unconditionally.
Siarhei Siamashka <siarhei.siamashka@gmail.com> writes:
You should try submitting it to linux-omap, this list is mostly users
and not kernel people. You may get more responses on the kernel
specific list.
Philip
