Nice and objective advice, I like it. In fact, the interrupt system works great to signal new data to be exchanged by the two PRUs, there are just the PRUs registers, no memory cache, everything completes in one pru cycle… a predictable word. I was lured to think that the same would happen to sync data between the PRU and the ARM.
Now I see that when I wrote “professional approach”, even stating that I am not a programmer, it may sounded offensive. So I ask, anyone who may felt uncomfortable, please forgive me. That was not my intention.
It is far more troubling to leave data variables uncleared once done with them, and not use memory use synchronization. As these can promote hard to nail down problems, as you’re observing.
Anyway, stop worrying about professional and what you think is professional, and focus on the things that are actually important.
Thank you very much. I will re-implement the code with this kind of flagging… maybe it is the right time to dive into some posix threads reading.
No no . . . what I mean by my comment was that it is more important to do a job right by you. Or put another way - Don’t worry so much about what other people think about your code, but do what works for you, and simpler code generally works best. Perhaps you’re familiar with the acronym K.I.S.S. ? e.g. “keep it simple stupid” . . . this is not meant as a denigrating remark. Actually the meaning I take from this is that there are usually more ways to do things ( in engineering ) and generally the simplest way is the best. For many reasons - But not always for the obvious reasons.
So my comment about the POSIX shared memory . . . The code was more of a high level concept than code that you can actually use for your situation. Honestly I have no idea how you would implement an equivalent PRU side, but I’m sure it is possible.
The beauty of the code is simplicity, and straight to the desired effect. No overhead, etc, and similar code could not get much faster . . . depending. One of the downsides however, is that it is a “blocking lock”. Which means the program can not do anything after this check, until it can do it’s thing with the shared data area. This can mean that one side or the other may stall while waiting on the other side to complete it’s task.
I also like the idea of using interrupts. However, there is probably lots of system overhead involved on the OS side - By comparison. Really though, I have no experience with using interrupts in / on an OS. Only bare metal. But the potential problem I’m seeing here - Is that I know that Linux works in time slices, and your Linux process will only get the CPU time the kernel lets it have. Which can be very non deterministic at times. I’ve experienced this first hand recently . .
Also, I’m going to assume, and it is probably a very good assumption that interrupts in Linux will require a system call at minimum. Which can be bad for an executable that needs to be fast. As an example - looks at the speed difference between accessing a file using sysfs compared to mmap(). sysfs uses systems calls, where mmap() does not. Well, for reading / writing. Initializing either is / can be very close to the same. Anyway, my personal experience here is with using POSIX semaphores. Compared to my simplistic code, they were dog slow. POSIX semaphores use system calls . . . my code does not. Being very simple code, and very little of it. Also is is also very deterministic. It virtually guarantees that only one side of the shared memory transaction can take place, and it has to take place in a certain order.
Interrupts between the two PRUs seems the way to go. Especially since it seems to be a single cycle operation on each side. For your Linux side application . . . I’m not so sure. But the only real way to find out is to implement two or more different ways of doing the same thing, and test it yourself.
Anyway . . . I’ve probably beat this horse to death
