PRU based frequency measurement
kernel 3.8.x
Thanks for the effort for addressing this problem in advance.
The following assembler and python files concists of my code to measure frequencies on the respectiver ports P8_15 and P8_16 using PRU0. The only problem being the outout of one of those frequency measured is always fluctuatung by a large margin (does show the actual output sometimes). I agree with the fact that this code can handle frequency measurement at one ports flawlessly I have checked for overflow of memory assigned at the shared ram and I can confirm that the flaw in output is not due to the overflow.Any help would be appreseated.
Thank you.
The following code is assembler code I have been using-
.origin 0
#define PRU0_ARM_INTERRUPT 19
#define CONST_PRUCFG C4
#define CONST_PRUSHAREDRAM C28
#define PRU0_CTRL 0x22000
#define PRU1_CTRL 0x24000
#define CTPPR0 0x28
#define OWN_RAM 0x000
#define OTHER_RAM 0x020
#define SHARED_RAM 0x100
#define SECOND 200000000 // 2e8 5ns cycles
#define DELAY 200 // 0.01 s
START:
lbco r0, CONST_PRUCFG, 4, 4 // Enable OCP master port
clr r0, r0, 4
sbco r0, CONST_PRUCFG, 4, 4
mov r0, SHARED_RAM // Set C28 to point to shared RAM
mov r1, PRU0_CTRL + CTPPR0
sbbo r0, r1, 0, 4
mov r2.w0, DELAY & 0xFFFF
mov r2.w2, DELAY >> 16
WAITLO:
qbbc WAITLO, r31.t15
IGNORE: // Wait for 50 consecutive readings of 1
add r0, r0, 2 // 3 cycles per loop
qbgt IGNORE, r0, r2
WAIT1: // Continue counting while input is still 1
add r0, r0, 2
qbbs WAIT1, r31.t15
WAIT2: // Continue counting while input is 0
add r0, r0, 2
qbbc WAIT2, r31.t15 // End count when input goes to 1
sbco r0, CONST_PRUSHAREDRAM, 0, 4 // Write count to RAM
MOV R31.b0, PRU0_ARM_INTERRUPT+16 // Send notification to Host for program completion
mov r0,0
WAITLO1:
qbbc WAITLO1, r31.t14
IGNORE1: // Wait for 50 consecutive readings of 1
qbgt IGNORE1, r0, r2
WAIT3: // Continue counting while input is still 1
add r0, r0, 2
qbbs WAIT3, r31.t14
WAIT4: // Continue counting while input is 0
add r0, r0, 2
qbbc WAIT4, r31.t14 // End count when input goes to 1
sbco r0, CONST_PRUSHAREDRAM,8 , 4 // Write count to RAM
mov r0, 0
jmp IGNORE
FREQ-MSR-ASSEM.p (2.07 KB)
BI-FREQ-MSR.py (2.63 KB)
