I have problem with the interrupts.
With this command I check if there is an interrupt
QBBS BACK_LOOP, r31, 30
How can I clear the interrupt?
I have tried to find a solution via from am335xPruReferenceGuide.pdf
"6.2.2.5 Interrupt Status Clearing
For clearing the status of an interrupt, whose interrupt number is N, write a 1 to the Nth bit position in the system interrupt status enabled/clear registers (SECR1-SECR2). System interrupt N can also be cleared by writing the value N into the system interrupt status indexed clear register (SICR)."
How can I do in practice?
