PRU I/O
Hello all,
I’m trying to use the PRU gpio pins, but cannot get them to work. I’ve modified Doctor Yoder’s device tree example to enable the PRU pins, but my program is still not getting the input. What am I doing wrong?
Here is my overlay:
/dts-v1/;
/plugin/;
compatible = “ti,beaglebone”, “ti,beaglebone-black”;
part-number = “MAY-gpio-set”;
version = “00A0”;
fragment@0 {
target = <&am33xx_pinmux>;
overlay {
pinctrl_test: MAY-gpio-set {
pinctrl-single,pins = <
0x0e4 0x36
0x0e0 0x36
fragment@1 {
target = <&ocp>;
overlay {
test_helper: helper {
compatible = “bone-pinmux-helper”;
pinctrl-names = “default”;
pinctrl-0 = <&pinctrl_test>;
status = “okay”;
Here’s mine:
/dts-v1/;
part-number = “AQ-PRU-MDIO”;
exclusive-use = “P8.43”, “P8.44”, “P8.45”, “P8.46”, “P8.39”, “P8.40”, “P8.41”, “P8.42”, “P8.27”, “P8.28”, “P8.29”, “P8.30”, “pru1”;
fragment@0 {
target = <0xdeadbeef>;
overlay {
pinmux_pru_mdio_pins {
pinctrl-single,pins = <0xa8 0xd 0xac 0xd 0xa0 0xd 0xa4 0xd 0xb8 0x35 0xbc 0x35 0xb0 0x35 0xb4 0x35 0xe0 0x36 0xe8 0x36 0xe4 0x36 0xec 0x36>;
linux,phandle = <0x1>;
phandle = <0x1>;
fragment@1 {
overlay {
status = “okay”;
pinctrl-0 = <0x1>;
symbols {
pru_mdio_pins = “/fragment@0/overlay/pinmux_pru_mdio_pins”;
fixups {
am33xx_pinmux = “/fragment@0:target:0”;
pruss = “/fragment@1:target:0”;
local_fixups {
fixup = “/fragment@1/overlay:pinctrl-0:0”;
I constructed mine by modifying one of the existing dts files on the beaglebone. I’ll admit I don’t completely understand it, but you could trimming it down to only your pins.
Thanks Brandon. I did get some of the pins working, but am getting all zeros on PRU1_R31 0 through 7. I’m trying to use the “interacto” pru code to capture images from a CMOS camera, which I’ve copied into my own repo: https://github.com/Rose-Hulman-ROBO4xx/1314-BeagleBone-Quadcopter/blob/master/code/i2c_bitbang/pru_sw/example_apps/camera/camera.p. PRU1_R31_16, 8, and 9 are definitely working, as the program will run to completion when I supply a clock to the camera, and does not run to completion when there is no clock. I’ve tested the memory mapping by moving dummy test values into r0 before storing it into dram at line 92, but when it comes time to actually store the camera’s data, I only get zeros, even when I wire one of the data pins to 3.3v (through a 2.2k resistor for safety). I’ve also confirmed that there is data coming from the camera using my BusPirate, which shows the voltage getting up to 2.76, and a frequency in the range of 1.8MHz, which does seem about right.
Any ideas why this is happening?
Ultimately, I’m not sure what was wrong. But for anyone who is having trouble with the device tree and the PRU, here is my device tree for the PRU code for my project:
/dts-v1/;
/plugin/;
        compatible = "ti,beaglebone", "ti,beaglebone-black";
        /* identification */
        part-number = "BB-CAMERA";
        version = "00A0";
        /* state the resources this cape uses */
        exclusive-use =
                /* the pin header uses */
                "P8.46",
                "P8.45",
                "P8.44",
                "P8.43",
                "P8.42",
                "P8.41",
                "P8.40",
                "P8.39",
                "P9.26",
                "P8.27",
                "P8.29",
                "P9.31",
                /* the hardware ip uses */
                "pruss";
        fragment@0 {
                __overlay__ {
                        bb_uart1_pins: pinmux_bb_uart1_pins {
                                        0x180 0x2e /* P9.26 uart1_rxd.uart1_rxd  INPUT  */
                                        0x0a4 0x2e
                                        0x0a0 0x2e
                                        0x0ac 0x2e
                                        0x0a8 0x2e
                                        0x0b4 0x2e
                                        0x0b0 0x2e
                                        0x0bc 0x2e
                                        0x0b8 0x2e
                                        0x180 0x2e
                                        0x0e0 0x2e
                                        0x0e4 0x2e
                                        0x190 0x26
        fragment@1 {
                target = <&uart2>;      /* really uart1 */
                __overlay__ {
                        status = "okay";
                        pinctrl-names = "default";
                        pinctrl-0 = <&bb_uart1_pins>;
