Hi Jason,
reduced the given example to a minimum, should toggle P8.45.
It doesn’t work.
Log of make:
root@beaglebone-ln:/media/SD32/home/ln/Programme/Puls_neu/source# make
CC puls_gen.c
“puls_gen.c”, line 82: warning #112-D: statement is unreachable
“puls_gen.c”, line 70: warning #179-D: variable “i” was declared but never referenced
“puls_gen.c”, line 70: warning #179-D: variable “j” was declared but never referenced
LD gen/puls_gen.obj
CC puls_gen.c
LD gen/decay95.obj
- Generated firmwares are : gen/puls_gen.out gen/decay95.out
root@beaglebone-ln:/media/SD32/home/ln/Programme/Puls_neu/source# config-pin overlay cape-universala
root@beaglebone-ln:/media/SD32/home/ln/Programme/Puls_neu/source# config-pin p8.45 pruout
root@beaglebone-ln:/media/SD32/home/ln/Programme/Puls_neu/source# config-pin -q p8.45
P8_45 Mode: pruout
root@beaglebone-ln:/media/SD32/home/ln/Programme/Puls_neu/source# make run
- copying firmware file gen/puls_gen.out to /lib/firmware/am335x-pru1-fw
/bin/sh: 1: cannot create /sys/bus/platform/drivers/pru-rproc/unbind: Permission denied
/bin/sh: 1: cannot create /sys/bus/platform/drivers/pru-rproc/bind: Permission denied
- rebooting pru core 0
- pru core 1 is now loaded with gen/puls_gen.out
My C-code:
#include <stdint.h>
#include <pru_cfg.h>
#include <pru_ctrl.h>
#include “resource_table_empty.h”
#define INS_PER_US 200 // 5ns per instruction
#define INS_PER_DELAY_LOOP 2 // two instructions per delay loop
#define DELAY_CYCLES_US (INS_PER_US / INS_PER_DELAY_LOOP)
#define GPIO1 0x4804C000
#define GPIO_CLEARDATAOUT 0x190
#define GPIO_SETDATAOUT 0x194
#define USR0 (1<<21)
#define USR1 (1<<22)
#define USR2 (1<<23)
#define USR3 (1<<24)
unsigned int volatile * const GPIO1_CLEAR = (unsigned int *) (GPIO1 + GPIO_CLEARDATAOUT);
unsigned int volatile * const GPIO1_SET = (unsigned int *) (GPIO1 + GPIO_SETDATAOUT);
volatile register unsigned int __R30;
volatile register unsigned int __R31;
#define PRU0_GPIO (1<<2)
#ifndef DECAY_RATE
#define DECAY_RATE 100
#endif
#ifndef DELAY_CYCLES
#define DELAY_CYCLES DELAY_CYCLES_US
#endif
const int decay = DECAY_RATE;
void main(void) {
int i, j;
/* Clear SYSCFG[STANDBY_INIT] to enable OCP master port */
CT_CFG.SYSCFG_bit.STANDBY_INIT = 0;
while (1)
__R30 |= 0x00000001; // toggle P8_45
__R30 &= 0xFFFFFFFE;
__halt();
Makefile is attached.
At the moment it works … and I know why … I can do the next step.
What is wrong or missing?
Thanks for help and have a good day
Kasimir
Makefile (2.79 KB)
