I seem to have discovered an anomaly with the __delay_cycles command trying to get precise timing on the PRU’s. Jason asked that I post my results for all to see.
My desire was to create a steady clock pulse on P8.11 and then set P8.12 low for just a single low cycle of P8.11. Then P8.12 was to go back high.
In using the __delay_cycles command, the timing on P8.12 was extremely random and would bounce back up to 3.3 volts immediately instead of staying low for a clock cycle. This can be seen in the following images.
However, replacing the __delay_cycles command with a “for” loop created output seen in the following image which is exactly what I needed.
I have no idea why the __delay_cycles is working this way. The really strange thing is if I cause P8.12 to follow P8.11, i.e. to rise when P8.11 rises and fall when P8.11 falls, then the output is exactly as expected. In fact, I can even make P8.12 to mirror P8.11 by causing it to fall when P8.11 rises and rise when P8.11 falls but not to stay down for just one low cycle of P8.11. Another interesting note is that the assembly code generated by the C compiler shows the delays exactly as one would expect but the output is still random. At any rate, the output pulses are as desired by using the “for” loops.
Here is the pertinent code. It contains both the working and non-working code. The non-working code is commented out and replaced with the “for” loops that do work.
The variables that set __R30 are hex values pertaining to the appropriate bits for pins P8.11 and P8.12. For example, gpioClockHighStartLow = 0x8000, gpioClockLowStartLow = 0x0000, gpioClockHighStartHigh = 0xC0000 and gpioClockLowStartHigh = 0x4000.
while(1){
for (resetCount = 0; resetCount < 100; resetCount++){
if (sensorState == STARTUP){ // Sensor is in startup mode
__R30 = gpioClockHighStartLow; //Set Clock High and Start Low
for (delayCount = 0; delayCount < 1000; delayCount++){
x++;
// __delay_cycles(1000);
__R30 = gpioClockLowStartLow; //Set Clock Low and Start Low
x++;
sensorState = RUNNING; // Indicate sensor is in running state
__R30 = gpioClockHighStartHigh; //Set Clock High and Start High
x++;
__R30 = gpioClockLowStartHigh; //Set Clock Low and Start High
x++;
resetCount = 0;
sensorState = STARTUP;
If anyone can shed any light on what I’m seeing with the __delay_cycles command I would be interested in hearing about it. Thanks.
Mike Pitman
