I have modified my earlier read program to use interrupts from the PRU Uart to the PRU.
See the Code at:https://github.com/jstampfl/PruUart_Int
The program for the PRU depends on the C program to do some of the initialization of the PRU interrupts. The PRU code initializes the Uart Rx interrupt which is System Event 6. The System Event 6 is mapped to channel 0 which is mapped to Host Interrupt 0 which appears on r31.t30 of the PRU.
.setcallreg r2.w0 // Just out of habit.
.origin 0
.entrypoint TB
TB:
ldi r20,0
ldi r21,0
ldi r22,0
mov r0,0
sbbo r0,r20,r21,4
zero &r0,64 //zero 16 registers
TB05:
sbbo r0,r20,r21,64 //zero some of pru0 local memory
add r21,r21,64 // for linux string functions
add r22,r22,1
qbgt TB05,r22,20
jmp ISET //this is the routine to setup
//interrupts
TB1:
// See section 8.2.1 in the AM335x PRU-ICSS Reference Guide
// for formula to compute the Uart divisor
ldi r3,4 //Uart divisor =1250 = 0x04E2
sbco r3,c7,0x24,4 // 9600 at 16x
ldi r3,0xE2 //in DLL & DLH
sbco r3,c7,0x20,4
ldi r3,1
sbco r3,c7,4,4 // turn on receiver interupts
lbco r3,c7,8,4 //read IIR to clear
ldi r3,0x3 //LCR = 3, 8 none & 1
sbco r3,c7,0x0C,4 //
mov r3,0x6001 //Power &
sbco r3,c7,0x30,4 // = tx on, rx on & Free to enable
mov r5,0xFFFFFF
ldi r4,0
ldi r4,0 //zero some registers
ldi r5,0
ldi r3,0
ldi r20,0
ldi r21,0
mov r9,276
ldi r11,0
ldi r24,0
call RSET // routine to clear & enable interrupts
// and get a character.
TB2:
qbbc TB2,r31.t30 // spin here for interrupt
call RSET // clear, enable & read
sbbo r3,r5,r4,1 // and put in buffer
add r4,r4,1
qbne TB2,r3,0xA // do until nl received
sbbo r20,r5,r4,1 // put null to terminate
ldi r4,0 // zero buffer pointer
mov r31.b0,35 // signal linux
jmp TB2
TB9: // an exit point used in debugging. Not used here
ldi r18,332 // offset to write errno
sbbo r23,r18,0,4 // used for debugging
HALT
ISET: // This section is to initialize the interrupts
mov r19,336 //point to printf in mem
lbco r13,c4,4,4 //enable OCP master port
clr r13,r13,4
sbco r13,c4,4,4
lbco r13,c4,0x2C,4 //disable MII_RT Events
ldi r13,0 // MII_RT Register in Pru cfg
sbco r13,c4,0x2C,4
mov r15,0x10 //Turn off global interrupts
lbco r14,c0,r15,4
clr r14,r14,0
sbco r14,c0,r15,4
mov r15,0x400 //set up Channel map
mov r14,0x09090909 // first map all unused events to
sbco r14,c0,r15,4 // Channel 9
mov r15,0x408
sbco r14,c0,r15,4
mov r15,0x40C // skiping offsets 410 & 414, they
sbco r14,c0,r15,4 // were set by the C program via prussdrv
mov r18,0x43C
mov r15,0x414
TB43:
add r15,r15,4
sbco r14,c0,r15,4
qbgt TB43,r15,r18
mov r14,0x00000909
mov r15,0x400 // now do offset 400
sbco r14,c0,r15,4 // only allow events 2 & 3
mov r14,0x09000000
mov r15,0x404 // now do 404, which has the
sbco r14,c0,r15,4 // entries for 4,5,6 the Uart interrupts
ldi r15, 0x24 //clear all events
call ALLEVT
mov r15,0x10
ldi r14,0x1
sbco r14,c0,r15,4
ldi r15,0x28 // enable all events
call ALLEVT
jmp TB1
RSET: // Routine to clear & enalbe system events, also host interrupts
// and read IIR in the Uart registers to clear the interrupt from
// the Uart. Also gets the character from the Uart buffer.
mov r24,r2 // Save return address
// so can call ALLEVT
mov r15,0x24 // to clear system event
call ALLEVT
mov r15,0x28 // to enable system event
call ALLEVT
lbco r3,c7,0,4 //data is ready, get from RBR
ldi r17,1
sbco r17,c7,4,4 // turn on receive interupts
mov r15,0x34 //HIEISR to enable host interrupt
ldi r14,0
sbco r14,c0,r15,4
ldi r14,2
sbco r14,c0,r15,4
ldi r14,3
sbco r14,c0,r15,4
mov r2,r24 // restore return address
ret
ALLEVT: //Insert the system envent in the proper resiger
// register r15 must have the register offset
// will only work with registers that take the event number
// if you want to handle multiple events, just add
// ldi r14,"sys event no."
// sbco r14, c0 ,r15,4
ldi r14,0x6
sbco r14, c0 ,r15,4
ret
