OK, I’m sure it is a stupid question but I don’t find it in AM335x TRM…there the offset of PRU_CTRL-register is defined with 0x00000000. But what is the base address? I found a definition 0x4a322000 in one of Starterware headers but this seems to be wrong.
So what is correct base address for PRU0 registers and RAM areas?
OK, the base address seems to be correct. Nevertheless CTRL-register isn ot readable, so it seems some important PRU-initialisations are missing. So is there any clock or power that has to be turned on for PRU?
If using a cape of some kind, this would normally be in the device tree setup for that cape.
If it’s your own custom cape, you would need to add this to your device tree file.
There may also be a suitable device tree overlay already installed in /lib/firmware that you can simply enable, but I don’t have my BBB in front of me right now to check.
OK, seems I have to clarify this a bit: in my environment no Linux is involved, I’m digging within the hardware directly.
What I found meanwhile: some clocks have to be enabled. But setting CM_PER_PRU_ICSS_CLKCTRL to 0x00000002 and CM_PER_PRU_ICSS_CLKSTCTRL to 0x00000010 (=CM_PER_PRU_ICSS_CLKSTCTRL_OCP_GCLK) did not do the trick.
