I’m having trouble getting PRU1 to recognize an event generated by PRU0. The examples I have found appear to be contradictory, so I hope someone can give me some help. I am using RemoteProc in a recent TI kernel on a PocketBeagle, and I can load and execute firmware just fine. PRU1 uses RPMSG, and I can generate and acknowledge events generated by the ARM to PRU1. I try to generate events on PRU0, directed to PRU1, and PRU1 is oblivious.
First of all, I have seen somewhere that PRU0-PRU1 is event 21, but I don’t understand where this is defined. On PRU0, my understanding is that I write to r31 with bit 5 set and the event in the lower 4 bits, so “ldi r31, 21+32” is what I am using on PRU0.
On PRU1, I want to map this event to host interrupt 0, so I can test bit 30 of R31 to see if the interrupt has occurred. In my resource table:
/* Mapping sysevts to a channel. Each pair contains a sysevt, channel. */
struct ch_map pru_intc_map = { {18, 3},
{19, 1},
{21, 0}
and
/* Channel-to-host mapping, 255 for unused */
0, 1, HOST_UNUSED, 3, HOST_UNUSED,
HOST_UNUSED, HOST_UNUSED, HOST_UNUSED, HOST_UNUSED, HOST_UNUSED,
Is this right? I have found one project where generating the interrupt involved subtracting 16 from the event written to R31.
