Mark A. Yoder <mark.a.yoder@gmail.com>
Fri, Aug 17, 7:58 AM
to BeagleBoard
The PRU cookbook is nearing completion (more accurately, I’m running out of summer).
Here’s a link https://markayoder.github.io/PRUCookbook/
I’m happy for any feedback you can give me.
–Mark
Great format, I really like it online.
To test it I choose a BeagleBone Black Wireless (as it turns out it was spare) and it already had a version 4.9 onit and upgraded it to
Linux beaglebone 4.14.69-ti-r75 #1 SMP PREEMPT Thu Sep 13 23:34:50 UTC 2018 armv7l GNU/Linux
Initially I followed instruction using USB, but then changed to wireless. Following is suggestions/observations
https://markayoder.github.io/PRUCookbook/02start/start.html
1.3. Flashing a Micro SD Card
Solution
Once the SD is flashed, insert it in the Beagle and power it up.
To permanently copy the image to the Beagle, copy it to Beagle flash.
[Reference to flashing beaglebone but post 4.4]
sudo nano \boot\uEnv.txt - remove from #cmdline
##enable BBB: eMMC Flasher:
cmdline=init=/opt/scripts/tools/eMMC/init-eMMC-flasher-v3.sh
toexit: save
sudo powerdown
Then press power button.
The device upgrades, and then powers down.
Remove uSD before pressing power switch.
1.4 Cloud9 IDE
for windows http://192.168.7.2:3000, for other computers see…
1.5 Getting Example Code
Setup for internet.
Ethernet - connected automatically
USB -
needs to be connected to the wireless
<comment 4.14.69-ti-r75 using USB>
The following is repeated a number of times in different place:
git clone https://github.com/MarkAYoder/PRUCookbook.git
Cloning into ‘PRUCookbook’…
fatal: unable to access ‘https://github.com/MarkAYoder/PRUCookbook.git/’: Could not resolve host: github.com
when setup for WiFi - it worked.
1.6. Blinking an LED
Running Code worked for me
https://markayoder.github.io/PRUCookbook/03details/details.html
1.2 Compiling and Running
debian@beaglebone:/var/lib/cloud9/git/PRUCookbook/docs/06io/code$ source gpio_setup.sh
PRUN=0
TARGET=gpio1
Wireless Not Found
$ cat /proc/device-tree/model
TI AM335x BeagleBone Black Wireless
workaround - make all defaults of pins P9_11
1.8 & 1.9 not checked.
