There isn’t really a “hello world” for remoteproc as you would have to write a kernel module or modify the remoteproc kernel module to do anything concrete with the PRU remoteproc driver as of now. Plus if vrings do not really suit your application, then you will have to develop your own userspace layer to expose functionality to userspace. I’ve done it with a character device in BeagleLogic - the buffers can be read(), mmap()-ed, and poll()-ed, and there’s some sysfs attributes and ioctl()'s for configuration. You might want to think of other possibilities depending upon your application.
The basic unit of communication between remoteproc and the PRU as of now is using downcalls and syscalls.
A syscall is when the PRU raises an IRQ and halts itself, storing some values in its registers. The kernel module handles the syscall IRQ, it reads the registers, manipulates them and resumes the PRU over the HALT instruction. See here for an example code of the syscall on the PRU side.
A downcall is initiated by the kernel module. Think of it as calling a function in the PRU from the kernel module and receiving the return value back in the kernel module.
The PRU has to be polling for the downcall, and it acknowledges with a special syscall. Then the function handle_downcall is called, which receives the downcall value and the parameters. So the handle_downcall (example) is a switch-case thing where the PRU does something and once it returns from this function, there is a syscall triggered which signals that the downcall is complete, the kernel module reads the return value of the function, after which the downcalling function in the kernel module returns with the return value.
I can go on and make thjs post TL;DR but the crux is that remoteproc currently is very application-specific and you have to twist and adapt the kernel module to your needs. Once the remoteproc stuff gets finalized, ideally there would be a generic framework and userspace layer on top of the driver to allow you to write your own applications from userspace, in a similar way as it is currently done using libprussdrv.
I’m speaking all this from experience gained while developing BeagleLogic, and that was for the 3.8.13 kernel. With the BeagleBoard community now migrating to a 3.14 based kernel, BeagleLogic will have to be ported to 3.14 which uses a new pru_rproc driver , and I will see how it can be done as there are differences between them, and some functionality will have to be added to the new driver.
Unfortunately I believe wading through thousands line of code would be the only option for now if you want to develop a new application.
