Pull-up resistors
Are pull up resistors required for the GPIO pins when used as inputs or as outputs for the beaglebone black? I am using the beaglebone to drive a few n-channel MOSFETs. Thanks!
The AM3358 has internal pullup/pulldown resistors available for GPIO inputs. These can be enabled using the universal-io . If you are using a current version of Debian, the device tree should already be included. The github overview shows how to use config-pin, the command “config-pin -h” shows how to engage the pullup/pulldown resistors. Chad
Pull up/down resistors are typically “required” by the circuit. In your case where you’re using a device that tends to be used as a switch. Leaving the circuit floating can cause unexpected behavior.
So, is it “required” ? No. Is it desired? Yes.
Also, I’m not exactly an EE, but the one EE I do know, seems to prefer using external pull up/down resistors. Why, I’m not sure, but perhaps someone who is an EE can explain why.
If you need a pin to be hi or low at power up, and you can’t afford to wait until the SW initializes the hardware, then you need to use a pullup or pulldown to make sure that pin is in the state you need. Some pins come up with the signals pulled hir or pulled lo. You should use those pins which have the default mode you need.
Also, these are weak pullups and pulldown resistors. They may not drive enough current to insure whatever is connected that it is indeed hi or lo on power up. You may need to add an external resistor to insure that it is where you want it to be.
Also note that the drive strength of the GPIO pins is limited. You need to use a resistor value that the processor can drive.
Also, I'm not exactly an EE, but the one EE I do know, seems to prefer
using external pull up/down resistors. Why, I'm not sure, but perhaps
You can control the values for external parts. Not all processors or
chips have internal resistors that can be enabled.
Example: cable tester, open drain outputs driving an input, chip
provided resistor 100K (not a processor)... That's rather high, and
susceptible to noise. 1K to 10K would be better, but would require
external parts.
lower the resistor value, more current flows, but the less susceptible
to noise you happen to be.
Harvey
