I am recently working on Beagle bone black, i need to use PWM module in the beagle bone black.
i followed the bellow steps for configuration :
cd /sys/class/pwm
ls → here i found pwmchip0, pwmchip1, pwmchip2, pwmchip3…pwmchip7.
cd pwmchip0
ls → here i found : device export npwm power subsystem uevent unexport.
echo 0 > export i added pwm0
ls → i can see pwm is added.
cd ./pwm0 → here i can see the duty cycle , period and other information.
i want to add the pinmux for pwm
debian@beaglebone:/sys/class/pwm$ config-pin -l P9.22
default gpio gpio_pu gpio_pd gpio_input spi_sclk uart i2c pwm pru_uart
debian@beaglebone:/sys/class/pwm$ config-pin P9.22 pwm
P9_22 pinmux file not found!
sudo: no askpass program specified, try setting SUDO_ASKPASS
Cannot write pinmux file: /sys/devices/platform/ocp/ocp*P9_22_pinmux/state
but it is showing error for adding P9.22 pin as pwm.
please help me to resolve it
In other hand if i try to add some more pwm means it is showing the error like this
debian@beaglebone:/sys/class/pwm$ cd pwmchip0
debian@beaglebone:/sys/class/pwm/pwmchip0$ ls
device export npwm power pwm-0:0 subsystem uevent unexport
debian@beaglebone:/sys/class/pwm/pwmchip0$ echo 3 > export
-bash: echo: write error: No such device
i am not able to add other pwm module… why it is showing the error.
please resolve it…
DTJF
July 30, 2019, 2:48pm
3
Insiders tip welcome?
Check out libpruio for easy and powerful PWM (and pinmuxing) features.
Regards
can anybody suggest me c programing example on the pwm in beagle-bone black.
using pwm i am doing some configuartions in the beaglebone black…
in /sys/class/pwm/pwmchip1
using pwm i am doing some configurations in the beagle bone black…
echo 0 > export
echo 1 > export
i can see the 2 pwm are added pwm1:0 , pwm1: 1
using cd pwm1:0 i am assigning the duty cycle , period and enable
if i rebooted the BBB means this configurations are erasing, why i am not getting??
using config-pin -l P9.14
config-pin P9.14 pwm
i am setting pin for pwm as p9.14
in hardware wise i am connecting 1 external led providing 1 connection from P9.14 and other end to ground.
but led should glow based on pwm duty-cycle, but here the LED not all glowing ???
please suggest me where i am missing??
Hi ,
i am using kernel version of 4.14.so slots file and bone -capemgr are disabled in V4.14 of kernel in the favor of U-boot overlay.
my uEnv.txt file look like this.
debian@beaglebone:/boot$ cat uEnv.txt
uname_r=4.14.71-ti-r80
#uuid=
#dtb=
###U-Boot Overlays###
###Documentation: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian#U-Boot_Overlays
###Master Enable
enable_uboot_overlays=1
Isn't this just a permission error? Does it work with sudo?
I got why that error is coming . already i used those pins to UART , so i can’t use that pins again to PWM.
i am using P9.14 for pwm, but still also it is not working for me…
i am feeling something i need to add in to uEnv.txt, but i am not getting …
please suggest me??
Hi Megha,
I recomend you to use adafruit python library to check your uEnv.tx configuration and pin choice. It is a very easy to use lib and helped me a lot to test GPIO stuff.
Here is a link to a simple tutorial:https://learn.adafruit.com/setting-up-io-python-library-on-beaglebone-black/pwm
