I want to write python code that will run on the Pocketbeagle on a good text editor like Visual Studio Code or PyCharm.
I know, I can copy paste code from my host computer to Pocketbeagle’s nano editor. But I suspect there must be a better way to do this.
I know for C/C++ there is remote cross compilers that can do the job. But I’m not able to find a suitable solution for Python yet.
Please help.
Thanks and Best regards
VS Code can be used…
Also, sftp can be used to just install everything from your dev. directory on the dev. machine.
So, sftp debian@IP_ADDRESS and then get or put depending on your way to push or pull the files in question.
I like to use sshfs for such purposes. The disadvantage is perhaps that for a new system I first have to create a directory once, which I then have to connect to my home directory on the target system.
mike@mpc4:~$ ls ~/Workspace/ssh/
asti0 bbbe ddc npim44 rpi1 rpi12 rpi14 rpi17 rpi2 rpi21 rpi4 rpi5 rpi9
bbai cm4io npiduo rpi0 rpi11 rpi13 rpi15 rpi19 rpi20 rpi3 rpi4b rpi8 wiki
mike@mpc4:~$ mkdir ~/Workspace/ssh/bplay
asti0 bbbe cm4io npiduo rpi0 rpi11 rpi13 rpi15 rpi19 rpi20 rpi3 rpi4b rpi8 wiki
bbai bplay ddc npim44 rpi1 rpi12 rpi14 rpi17 rpi2 rpi21 rpi4 rpi5 rpi9
mike@mpc4:~$ sshfs debian@bplay:/home/debian /home/mike/Workspace/ssh/bplay
debian@bplay's password:
mike@mpc4:~$ ls ~/Workspace/ssh/bplay/
Desktop Documents Downloads examples Music Pictures Public Templates Videos
mike@mpc4:~$ ssh debian@bplay
Debian GNU/Linux 11
BeagleBoard.org Debian Bullseye Xfce Image 2023-02-04
Support: https://bbb.io/debian
default username:password is [debian:temppwd]
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Fri Mar 17 08:02:07 2023 from 192.168.178.24
debian@bplay:~$ ls
debian@bplay:~$
mike@mpc4:~$ touch ~/Workspace/ssh/bplay/empty.py
Desktop Documents Downloads empty.py examples Music Pictures Public Templates Videos
mike@mpc4:~$ chmod 755 ~/Workspace/ssh/bplay/empty.py
mike@mpc4:~$ ls -lA ~/Workspace/ssh/bplay/*.py
-rwxr-xr-x 1 mike mike 0 17. Mär 09:08 /home/mike/Workspace/ssh/bplay/empty.py
debian@bplay:~$ ls
debian@bplay:~$ ls -lA *.py
-rwxr-xr-x 1 debian debian 0 Mar 17 08:08 empty.py
How To Use SSHFS to Mount Remote File Systems Over SSH
My BeaglePlay already had sshfs installed on delivery.
Generally using KDE, I just use dolphin to access the remote system and if editing anything then use kate and it will open remote files directly and save back again. No need to mount anything.
Putting ssh public key on the remote system, makes it all transparent.
