I haven't been part of this list for a while and my Beagleboard has
been running Lenny happily for a long time now. I want to make to
jump to squeeze and tried the usual "apt-get dist-upgrade" but that
didn't do anything.
Additionally I haven't found any discussions/how to's on doing this
specifically for Beagleboard (or ARM in general) via my google
searches.
Is there a viable procedure to upgrade to squeeze from lenny on the
Beagleboard?
Alternately am I better off just doing a fresh load of squeeze and
porting all my software & customizations one by one? (This is the
route I'm trying to avoid since I usually access my Beagleboard
remotely and swapping SD cards is not an option in that scenario)
Any and all suggestions & links to how to's would be greatly
appreciated.
Some information about my board & OS:
Debian Version : 5.0.8
Beagleboard : Revision C4
U-Boot Version :
Kernel Version : Linux beagleboard 2.6.34.4-x2 #1 PREEMPT Sat Aug 14
02:57:06 UTC 2010 armv7l GNU/Linux
dmesg : http://pastebin.com/EYLiWgsw
sudo apt-get update
sudo apt-get install apt aptitude udev
(possible reboot, but the 2.6.35.x kernel should be fine with out..)
sudo aptitude update
sudo aptitude safe-upgrade
then maybe a
sudo aptitude dist-upgrade (but double check the packages it want's to install)
I am pleased to report I have successfully upgraded my Debian Beagleboard.
I followed the pre-upgrade step from this [1] article which talks about updating and cleaning up packages before upgrading. I did have a couple dozen orphaned packages so this was definitely a worthwhile exercise.
Secondly I followed Robert advice but I ran into some trouble with “aptitude safe-upgrade”. I ran it twice and both times it just ran the CPU at 100% and consumed all the memory, then started swapping. It never completed the “Resolving dependencies” stage. So I went with aptitude dist-upgrade and it only needed to remove the sysvconfig package so I felt confident proceeding in this manner.
Third, I added to Robert recommendations by picking up the latest stable squeeze kernel.
And lastly, I [2] blogged it for reference (mostly mine since I’ll forget what I did in a couple of months).
