While digging through Robert Nelson’s omap image builder, I noticed that he’s using Qemu at some point to emulate the Beagle Bone from the PC and download/install packages.
Digging through his code left me confused… I understand he is using the qemu-arm-static executable in order to execute a sequence of commands, but he also seems to be pulling some code from linuxCnC for the emulator image, leaving me confused.
What I’d like to do is use qemu-arm-system to boot up an image close to the BeagleBoneBlack in compatibility so I can do some compilation and installation from my desktop into the image. https://wiki.edubuntu.org/ARM/RootfsFromScratch has instructions for setting this up to a degree, but it uses a rather old distribution and kernel[using armel instead of armhf].
Checking the current netboot images for omap4, http://ports.ubuntu.com/ubuntu-ports/dists/raring/main/installer-armhf/current/images/omap4/netboot/ the image files are different and include uBoot images rather than the single vmlinuz file[though that file is available under the generic folder, http://ports.ubuntu.com/ubuntu-ports/dists/raring/main/installer-armhf/current/images/generic/netboot/]
Can someone give me a summary of how to invoke qemu-arm-system to use the latest released omap4 images from http://ports.ubuntu.com/ubuntu-ports/dists/raring/main/installer-armhf/current/images/omap4/netboot/ ?
Also, do I need to get qemu from someplace specific to get a cpu/system emulator compatible with the BeagleBone? I’m running QEMU emulator version 1.4.0 (Debian 1.4.0+dfsg-1expubuntu4) and the cpu options are:
Available CPUs:
arm1026
arm1136
arm1136-r2
arm1176
arm11mpcore
arm926
arm946
cortex-a15
cortex-a8
cortex-a8-r2
cortex-a9
cortex-m3
pxa250
pxa255
pxa260
pxa261
pxa262
pxa270-a0
pxa270-a1
pxa270
pxa270-b0
pxa270-b1
pxa270-c0
pxa270-c5
sa1100
sa1110
ti925t
any
Thanks in advance for any help
While digging through Robert Nelson's omap image builder, I noticed that
he's using Qemu at some point to emulate the Beagle Bone from the PC and
Digging through his code left me confused... I understand he is using the
<snip>
Robert's image builder isn't actually pulling in anything from LinuxCNC,
those are hooks for my MachineKit image:
...which is built with Robert's scripts and a slightly different
configuration. Robert has pulled my changes to his scripts and left the
MachineKit configuration files as an example of how to build a custom
image. If you don't create a custom config file (based on config.in or
config.machinekit), you'll get Robert's default build of various Debian
and Ubuntu images.
As for the qemu directions, it's super simple:
Setup a root filesystem for an ARM device. You can use debootstrap to
make one from scratch (the way Robert's scripts do), or use one of the
various pre-made root filesystems.
Copy the qemu-arm-static binary into ${arm-root-fs}/usr/bin/
arm-root-fs=/path/to/arm/root/filesystem/
sudo cp $(which qemu-arm-static) ${arm-root-fs}/usr/bin/
Then all you do is:
sudo chroot ${arm-root-fs} /bin/sh
...and you're running a shell in your arm rootfs. Type uname -a and
notice you are no longer on an x86 CPU!
"qemu-arm-static" != full qemu... We are just using userspace qemu arm
emulation.. Using a full virtual qemu machine was a pain in the ass
and we dropped using that directly around ubuntu lucid time frame..
"linuxCNC" is another project that utilize the omap-image-builder
infrastructure, thus many of their extra build stuff is in the repo..
What I'd like to do is use qemu-arm-system to boot up an image close to the
ARM/RootfsFromScratch - Ubuntu Wiki has instructions for setting
If your going to follow that wiki, make sure to get a time machine,
everything used on the page went EOL/un-maintained 2 years ago... (i
was one of the last developers/users using it, i ended up re-writing
the useful parts in my omap-image-builder scripts, hence the
"RootStock-NG.sh" name of one script..)
Slow down a bit…
> [http://ports.ubuntu.com/ubuntu-ports/dists/raring/main/installer-armhf/current/images/omap4/netboot/](http://www.google.com/url?q=http%3A%2F%2Fports.ubuntu.com%2Fubuntu-ports%2Fdists%2Fraring%2Fmain%2Finstaller-armhf%2Fcurrent%2Fimages%2Fomap4%2Fnetboot%2F&sa=D&sntz=1&usg=AFQjCNHq5GkpdfBYh075PkJNWzM6EkKPFQ)
Robert’s image builder isn’t actually pulling in anything from LinuxCNC,
http://bb-lcnc.blogspot.com/p/machinekit_16.html
…which is built with Robert’s scripts and a slightly different
image. If you don’t create a custom config file (based on config.in or
config.machinekit), you’ll get Robert’s default build of various Debian
and Ubuntu images.
As for the qemu directions, it’s super simple:
make one from scratch (the way Robert’s scripts do), or use one of the
Which is this? It makes me think it’s the SD card image, but…I’m not flashing my real Beaglebone for this exercise!
Then all you do is:
…and you’re running a shell in your arm rootfs. Type uname -a and
OK, this chroot procedure kind of reminds me of when my grub bootloader kept dying on me everytime I tried to “fix” it. But I’m still not sure what reference to use for building the root file system.
I want to automate installation of additional packages to default BBB image without using real device.
Option 1: qemu static
Problem here I have no network:
ping 8.8.8.8
qemu: Unsupported syscall: 184
ping: cap_get_proc: Function not implemented
Do you have network working when you build images?
Option 2: Use full VM
qemu-system-arm -M versatilepb -cpu cortex-a8 -kernel ./vmlinuz -hda BBB-eMMC-flasher-ubuntu-13.10-2014-01-24-2gb.img -m 256 -append “root=/dev/sda2 rootfstype=ext4 rw” -redir tcp:5022::22
kernel: http://ports.ubuntu.com/ubuntu-ports/dists/lucid/main/installer-armel/current/images/versatile/netboot/vmlinuz
On boot it says ‘The disk drive for /boot/ubuut is not ready, press S to skip’
If I press S it boots fine and I can run my build procedure.
Do you know if that uboot can disabled/auto skipped?
For the reference my similar raspberry image builder: https://github.com/syncloud/owncloud-setup/blob/master/build-image.sh
Thanks you.
You might want to try adding something like the following to your qemu
calling parameters:
-net nic,model=rtl8139 -net user
regards,
Nuno
Qemu static means you do not run vm, it is just chroot into /path/to/arm/root/filesystem
having qemu-arm-static in /path/to/arm/root/filesystem/usr/bin
You provided argument for qemu vm which is second option in my question and I have no network issues there, only uboot question.
Thanks.
Finally I figured out: http://geek.co.il/2010/03/14/how-to-build-a-chroot-jail-environment-for-centos
losetup -o 101711872 /dev/loop0 BBB-eMMC-flasher-ubuntu-13.10-2014-02-16-2gb.img
mount /dev/loop0 image
sudo mount --bind /dev image/dev
sudo mount --bind /proc image/proc
mkdir image/run/resolvconf
cp /run/resolvconf/resolv.conf image/run/resolvconf/resolv.conf
That fixed chroot network problems.
I also decided to build new images on device (no qemu at all) in chrooted environment in “continuous integration” mode.
Thanks.
