I hope there is someone here successfully using QNX on the BBB. I am currently doing a QNX evaluation and am having trouble with the BBB BSP. I am using the BSP_ti-am335x-beaglebone_br-660_be-660_SVN797070_JBN574.zip BSP. The package comes with a pre-built image, which boots up fine. I have been able to do a few test programs with it, but now I need to modify the BSP to change which features are used. The first step in doing this was to just recompile the BSP to make sure I can recreate the precompiled version. The build goes fine and creates an image. I can boot off the image, but it gives a lot of errors:
U-Boot# fatload mmc 0 81000000 ifs-ti-am335x-beaglebone.bin
reading ifs-ti-am335x-beaglebone.bin
5794620 bytes read in 657 ms (8.4 MiB/s)
U-Boot# go 81000000
Starting application at 0x81000000 …
Board ID
header: ee3355aa
I am using QNX 6.50 on the BBB and have no problems.
Are the executables in question on a FAT32 partition? If so, execute permissions can’t be set. Are you booting from SD card or eMMC? What do your partition tables look like on your boot device (fdisk view)? What is the output of the mkifs command in the images directory? Post your .build file.
Thank you so much for the reply! I’m just getting started with QNX, so I need all the help I can get.
I am booting from the SD card. .build file is attached and is exactly as shipped with the BSP, so I assumed it was the same they build the prebuilt image with. I build the SDCard by formatting it as FAT32, then I copy the MLO, u-boot.img and the image file generated when I build the BSP.
I’m gonna need a little more guidance on the fdisk command. Like I said, new to QNX - I can’t find a device which seems to be a disk device. Here is the contents of /dev:
ls /dev
bpf name slog tap0 tun1
bpf0 null snd tap1 tun2
console pipe socket tap2 tun3
crypto screen stderr tap3 tymem
io-usb sem stdin text zero
io-usb-dcd serusb1 stdout tty
mem shmem tap tun0
mkifs output is pasted below:
mkifs -r…/install -v beaglebone.build ifs-ti-am335x-beaglebone.bin
Offset Size Entry Ramoff Target=Host
81000000 8 0 — /home/shartmann/qnx660/target/qnx6/armle-v7/boot/sys/raw.boot
81000008 100 ---- — Startup-header
81000108 24010 8100363c — /tmp/fileBOOEZr
81024110 5c ---- — Image-header
8102416c 2218 ---- — Image-directory
81027000 8b000 fe05a4f0 — proc/boot/procnto-instr=/tmp/file6Oj0yG
810b2000 858 ---- — proc/boot/.script=/tmp/file9JFO1Y
---- — ---- — bin/sh=/proc/boot/ksh
---- — ---- — dev/console=/dev/ser1
---- — ---- — tmp=/dev/shmem
---- — ---- — var/log=/tmp
---- — ---- — usr/tmp=/tmp
810c0000 8f1fe 46884 — proc/boot/libc.so.3=/home/shartmann/qnx660/target/qnx6/armle-v7/lib/libc.so
---- — ---- — proc/boot/libc.so=libc.so.3
81150000 22e7f 5748 — proc/boot/libm.so.2=/home/shartmann/qnx660/target/qnx6/armle-v7/lib/libm.so
---- — ---- — proc/boot/libm.so=libm.so.2
81180000 f732 416c — proc/boot/libcam.so.2=/home/shartmann/qnx660/target/qnx6/armle-v7/lib/libcam.so
---- — ---- — proc/boot/libcam.so=libcam.so.2
81190000 27b46 6c58 — proc/boot/io-blk.so=/home/shartmann/qnx660/target/qnx6/armle-v7/lib/dll/io-blk.so
811b8000 4660 e58 — proc/boot/cam-disk.so=/home/shartmann/qnx660/target/qnx6/armle-v7/lib/dll/cam-disk.so
811bd000 55bc f98 — proc/boot/cam-cdrom.so=/home/shartmann/qnx660/target/qnx6/armle-v7/lib/dll/cam-cdrom.so
811d0000 16602 38f0 — proc/boot/fs-qnx6.so=/home/shartmann/qnx660/target/qnx6/armle-v7/lib/dll/fs-qnx6.so
811e7000 d4d1 237c — proc/boot/fs-qnx4.so=/home/shartmann/qnx660/target/qnx6/armle-v7/lib/dll/fs-qnx4.so
811f5000 128ec 2b20 — proc/boot/fs-dos.so=/home/shartmann/qnx660/target/qnx6/armle-v7/lib/dll/fs-dos.so
81210000 1274c 2d58 — proc/boot/fs-udf.so=/home/shartmann/qnx660/target/qnx6/armle-v7/lib/dll/fs-udf.so
81223000 b6c6 22fc — proc/boot/fs-cd.so=/home/shartmann/qnx660/target/qnx6/armle-v7/lib/dll/fs-cd.so
8122f000 98c7 2430 — proc/boot/devu-dm816x-mg.so=…/install/armle-v7/lib/dll/devu-dm816x-mg.so
81239000 a65e 36f8 — proc/boot/libusbdi.so.2=/home/shartmann/qnx660/target/qnx6/armle-v7/lib/libusbdi.so
---- — ---- — proc/boot/libusbdi.so=libusbdi.so.2
81244000 8a2b 1e04 — proc/boot/devu-usbumass-am335x-musbmhdrc.so=…/install/armle-v7/lib/dll/devu-usbumass-am335x-musbmhdrc.so
8124d000 8b29 1f94 — proc/boot/devu-usbser-am335x-musbmhdrc.so=…/install/armle-v7/lib/dll/devu-usbser-am335x-musbmhdrc.so
81256000 8ada 1f08 — proc/boot/devu-usbncm-am335x-musbmhdrc.so=…/install/armle-v7/lib/dll/devu-usbncm-am335x-musbmhdrc.so
8125f000 a523 36f8 — proc/boot/libusbdci.so.2=/home/shartmann/qnx660/target/qnx6/armle-v7/lib/libusbdci.so
---- — ---- — proc/boot/libusbdci.so=libusbdci.so.2
81270000 14c9c 4770 — proc/boot/devnp-usbdnet.so=/home/shartmann/qnx660/target/qnx6/armle-v7/lib/dll/devnp-usbdnet.so
81285000 4f84 1240 — proc/boot/spi-dm816x.so=…/install/armle-v7/lib/dll/spi-dm816x.so
8128a000 13018 4520 — proc/boot/devnp-dm814x-am335x.so=…/install/armle-v7/lib/dll/devnp-dm814x-am335x.so
812a0000 20d7d 5f80 — proc/boot/libsocket.so.3=/home/shartmann/qnx660/target/qnx6/armle-v7/lib/libsocket.so
---- — ---- — proc/boot/libsocket.so=libsocket.so.3
812d0000 52f5 198c — proc/boot/libtracelog.so.1=/home/shartmann/qnx660/target/qnx6/armle-v7/lib/libtracelog.so.1
---- — ---- — proc/boot/libtracelog.so=libtracelog.so.1
812d6000 5278 1bdc — proc/boot/libhiddi.so.1=/home/shartmann/qnx660/target/qnx6/armle-v7/lib/libhiddi.so.1
---- — ---- — proc/boot/libhiddi.so=libhiddi.so.1
812dc000 941c 275c — usr/lib/libdisputil.so.2=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/lib/libdisputil.so.2
---- — ---- — usr/lib/libdisputil.so=libdisputil.so.2
812e6000 5271 16e8 — usr/lib/libWFD.so.1=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/lib/libWFD.so.1
---- — ---- — usr/lib/libWFD.so=libWFD.so.1
812ec000 a36d 2300 — usr/lib/libinputevents.so.1=/home/shartmann/qnx660/target/qnx6/armle-v7/lib/libinputevents.so.1
---- — ---- — usr/lib/libinputevents.so=libinputevents.so.1
812f7000 219c 548 — usr/lib/libkalman.so.1=/home/shartmann/qnx660/target/qnx6/armle-v7/lib/libkalman.so.1
---- — ---- — usr/lib/libkalman.so=libkalman.so.1
812fa000 31fa 8bc — lib/dll/screen-pvr2d.so=/home/shartmann/qnx660/target/qnx6/armle-v7/lib/dll/screen-pvr2d.so
812fe000 a38c 1600 — lib/dll/screen-gles2.so=/home/shartmann/qnx660/target/qnx6/armle-v7/lib/dll/screen-gles2.so
81310000 382ec 2ec0 — usr/lib/graphics/am335x/libsrv_um.so=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/lib/graphics/am335x/libsrv_um.so
81349000 7277 168c — usr/lib/graphics/am335x/libpvr2d.so=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/lib/graphics/am335x/libpvr2d.so
81360000 191f9 8e8 — usr/lib/graphics/am335x/pvrsrvinit.so=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/lib/graphics/am335x/pvrsrvinit.so
81380000 3e499 6618 — usr/lib/graphics/am335x/pvrsrv.so=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/lib/graphics/am335x/pvrsrv.so
813bf000 75fe 1fe0 — usr/lib/graphics/am335x/libWFDam335x-bbb.so=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/lib/graphics/am335x/libWFDam335x-bbb.so
813c7000 42f2 ae0 — usr/lib/graphics/am335x/libwfdcfg.so.0=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/lib/graphics/am335x/libwfdcfg-am335x-bbb.so
---- — ---- — usr/lib/graphics/am335x/libwfdcfg-am335x-bbb.so=libwfdcfg.so.0
813cc000 5c1 ---- — usr/lib/graphics/am335x/graphics.conf=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/lib/graphics/am335x/graphics.conf.bbb
813cd000 9b66 2bd0 — usr/lib/libEGL.so.1=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/lib/libEGL.so.1
---- — ---- — usr/lib/libEGL.so=libEGL.so.1
813d7000 11339 34ac — usr/lib/libscreen.so.1=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/lib/libscreen.so.1
---- — ---- — usr/lib/libscreen.so=libscreen.so.1
813e9000 c175 38a8 — usr/lib/libGLESv1_CM.so.1=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/lib/libGLESv1_CM.so.1
---- — ---- — usr/lib/libGLESv1_CM.so=libGLESv1_CM.so.1
813f6000 9163 2a20 — usr/lib/libGLESv2.so.1=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/lib/libGLESv2.so.1
---- — ---- — usr/lib/libGLESv2.so=libGLESv2.so.1
81400000 eb25d 5998 — usr/lib/graphics/am335x/libusc.so=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/lib/graphics/am335x/libusc.so
814f0000 132ac 19c0 — usr/lib/graphics/am335x/libIMGegl.so=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/lib/graphics/am335x/libIMGegl.so
81504000 6383 1378 — usr/lib/graphics/am335x/wsegl-screen.so=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/lib/graphics/am335x/wsegl-screen.so
81510000 7f4d6 3a00 — usr/lib/graphics/am335x/libImgGLESv1_CM.so=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/lib/graphics/am335x/libImgGLESv1_CM.so
81590000 73463 3368 — usr/lib/graphics/am335x/libImgGLESv2.so=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/lib/graphics/am335x/libImgGLESv2.so
81610000 4a292 16d0 — usr/lib/graphics/am335x/libglslcompiler.so=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/lib/graphics/am335x/libglslcompiler.so
81660000 251ec 8e58 — proc/boot/libasound.so.2=/home/shartmann/qnx660/target/qnx6/armle-v7/lib/libasound.so.2
---- — ---- — proc/boot/libasound.so=libasound.so.2
81690000 11517 4b58 — proc/boot/libaudio_manager.so.1=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/lib/libaudio_manager.so.1
---- — ---- — proc/boot/libaudio_manager.so=libaudio_manager.so.1
816a2000 525a 16b8 — proc/boot/libpps.so.1=/home/shartmann/qnx660/target/qnx6/armle-v7/lib/libpps.so.1
---- — ---- — proc/boot/libpps.so=libpps.so.1
816a8000 908c 1708 — proc/boot/deva-ctrl-mcasp-dm814x_tda19988.so=…/install/armle-v7/lib/dll/deva-ctrl-mcasp-dm814x_tda19988.so
816b2000 41d ---- — etc/system/config/cacheflags.conf=…/install/etc/system/config/cacheflags.conf
816b3000 4a4 ---- — proc/boot/.console.sh=/tmp/filew7fvrd
816c0000 3e511 804f984 — sbin/screen=/home/shartmann/qnx660/target/qnx6/armle-v7/sbin/screen
816ff000 5c45 804a208 — usr/bin/gles1-gears=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/bin/gles1-gears
81705000 7878 804a528 — usr/bin/gles2-gears=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/bin/gles2-gears
8170d000 72af 804a300 — usr/bin/sw-vsync=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/bin/sw-vsync
81720000 226b3 804f224 — proc/boot/io-audio=/home/shartmann/qnx660/target/qnx6/armle-v7/sbin/io-audio
81743000 4dff 804a3c0 — proc/boot/wave=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/bin/wave
81748000 6d59 8049d78 — proc/boot/mix_ctl=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/bin/mix_ctl
8174f000 b415 804a334 — proc/boot/devc-seromap=…/install/armle-v7/sbin/devc-seromap
8175b000 4ab4 8049b74 — bin/stty=/home/shartmann/qnx660/target/qnx6/armle-v7/bin/stty
81760000 13e69 804aae0 — proc/boot/devb-sdmmc-j5_generic=…/install/armle-v7/sbin/devb-sdmmc-j5_generic
81774000 545c 8049530 — proc/boot/i2c-omap35xx-j5=…/install/armle-v7/sbin/i2c-omap35xx-j5
8177a000 2b82 8048d98 — proc/boot/am335x-boardid=…/install/armle-v7/sbin/am335x-boardid
8177d000 de29 804a2b0 — proc/boot/rtc=…/install/armle-v7/sbin/rtc
8178b000 4379 8049800 — proc/boot/date=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/bin/date
81790000 34ce 804934c — proc/boot/spi-master=…/install/armle-v7/sbin/spi-master
81794000 26b5 8048cf4 — proc/boot/am335x-leds=…/install/armle-v7/sbin/am335x-leds
817a0000 19e65 804bb38 — proc/boot/io-usb=/home/shartmann/qnx660/target/qnx6/armle-v7/sbin/io-usb
817ba000 6ad7 8049210 — proc/boot/usb=/home/shartmann/qnx660/target/qnx6/armle-v7/sbin/usb
817c1000 86a6 804a420 — proc/boot/devb-umass=/home/shartmann/qnx660/target/qnx6/armle-v7/sbin/devb-umass
817ca000 3f21 80492b8 — proc/boot/devb-ram=/home/shartmann/qnx660/target/qnx6/armle-v7/sbin/devb-ram
817d0000 174cb 804b980 — proc/boot/io-usb-dcd=/home/shartmann/qnx660/target/qnx6/armle-v7/sbin/io-usb-dcd
817e8000 57a4 8049848 — proc/boot/ulink_ctrl=/home/shartmann/qnx660/target/qnx6/armle-v7/sbin/ulink_ctrl
817ee000 f64f 804a008 — proc/boot/devu-umass_client-block=/home/shartmann/qnx660/target/qnx6/armle-v7/sbin/devu-umass_client-block
817fe000 10b49 804a870 — proc/boot/devc-serusb_dcd=/home/shartmann/qnx660/target/qnx6/armle-v7/sbin/devc-serusb_dcd
81810000 ca6bb 805fe64 — proc/boot/io-pkt-v4-hc=/home/shartmann/qnx660/target/qnx6/armle-v7/sbin/io-pkt-v4-hc
818db000 16466 804a5e8 — proc/boot/ifconfig=/home/shartmann/qnx660/target/qnx6/armle-v7/sbin/ifconfig
818f2000 2681 8048cf0 — proc/boot/if_up=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/sbin/if_up
818f5000 3b2c 8048d54 — proc/boot/nicinfo=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/sbin/nicinfo
81900000 17b24 804aae4 — proc/boot/netstat=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/bin/netstat
81918000 896b 804aaf4 — proc/boot/ping=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/bin/ping
81921000 62a4 804a0b4 — proc/boot/route=/home/shartmann/qnx660/target/qnx6/armle-v7/sbin/route
81928000 149de 8049970 — proc/boot/setkey=/home/shartmann/qnx660/target/qnx6/armle-v7/sbin/setkey
8193d000 d227 8049f98 — proc/boot/dhcp.client=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/sbin/dhcp.client
8194b000 2b4c 8048cdc — proc/boot/dm814x-wdtkick=…/install/armle-v7/bin/dm814x-wdtkick
8194e000 a6ff 804a1e4 — proc/boot/devc-pty=/home/shartmann/qnx660/target/qnx6/armle-v7/sbin/devc-pty
81960000 1742f 804b87c — proc/boot/qconn=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/sbin/qconn
81978000 89e2 8049964 — usr/bin/pdebug=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/bin/pdebug
81990000 138e2 804aa50 — proc/boot/fs-cifs=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/sbin/fs-cifs
819a4000 11b7b 804afb0 — proc/boot/fs-nfs3=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/sbin/fs-nfs3
819c0000 380a5 804bc2c — proc/boot/ftp=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/bin/ftp
819f9000 925a 804af28 — proc/boot/inetd=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/sbin/inetd
81a10000 120cc 804a158 — usr/sbin/telnetd=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/sbin/telnetd
81a30000 197bd 804bbbc — usr/sbin/ftpd=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/sbin/ftpd
81a4a000 73ee 8049e14 — bin/login=/home/shartmann/qnx660/target/qnx6/armle-v7/bin/login
81a52000 23f1 8048b2c — proc/boot/cat=/home/shartmann/qnx660/target/qnx6/armle-v7/bin/cat
81a55000 49ad 8049204 — proc/boot/ls=/home/shartmann/qnx660/target/qnx6/armle-v7/bin/ls
81a60000 1e5ec 804abc0 — proc/boot/ksh=/home/shartmann/qnx660/target/qnx6/armle-v7/bin/ksh
81a7f000 3f11 8049394 — proc/boot/mount=/home/shartmann/qnx660/target/qnx6/armle-v7/bin/mount
81a83000 4dff 8049fc4 — proc/boot/pipe=/home/shartmann/qnx660/target/qnx6/armle-v7/sbin/pipe
81a88000 10b04 804a744 — proc/boot/pidin=/home/shartmann/qnx660/target/qnx6/armle-v7/bin/pidin
81a99000 21b4 8048a10 — proc/boot/uname=/home/shartmann/qnx660/target/qnx6/armle-v7/bin/uname
81a9c000 3c59 80493f8 — proc/boot/shutdown=/home/shartmann/qnx660/target/qnx6/armle-v7/bin/shutdown
81aa0000 21dc 8048b44 — proc/boot/sleep=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/bin/sleep
81aa3000 3fcc 80496f8 — proc/boot/slogger=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/sbin/slogger
81aa7000 2a95 80490ac — proc/boot/sloginfo=/home/shartmann/qnx660/target/qnx6/armle-v7/bin/sloginfo
81aaa000 446b 8049854 — proc/boot/slay=/home/shartmann/qnx660/target/qnx6/armle-v7/bin/slay
81aaf000 1ef9 80488d0 — proc/boot/umount=/home/shartmann/qnx660/target/qnx6/armle-v7/bin/umount
81ab1000 28bf 8048bb8 — proc/boot/mkdir=/home/shartmann/qnx660/target/qnx6/armle-v7/bin/mkdir
81ab4000 1ec1 804882c — proc/boot/rmdir=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/bin/rmdir
81ab6000 2d70 80491fc — proc/boot/mv=/home/shartmann/qnx660/target/qnx6/armle-v7/bin/mv
81ab9000 7c05 8049fcc — proc/boot/cp=/home/shartmann/qnx660/target/qnx6/armle-v7/bin/cp
81ac1000 2d87 8048d88 — proc/boot/rm=/home/shartmann/qnx660/target/qnx6/armle-v7/bin/rm
81ac4000 9358 804ab94 — proc/boot/on=/home/shartmann/qnx660/target/qnx6/armle-v7/bin/on
81ad0000 4821d 804a4f4 — proc/boot/elvis=/home/shartmann/qnx660/target/qnx6/armle-v7/bin/elvis
81b19000 62aa 8049994 — proc/boot/df=/home/shartmann/qnx660/target/qnx6/armle-v7/bin/df
81b20000 2fdd 8048f64 — proc/boot/ln=/home/shartmann/qnx660/target/qnx6/armle-v7/bin/ln
81b23000 2e4c 8048dc0 — proc/boot/chmod=/home/shartmann/qnx660/target/qnx6/armle-v7/bin/chmod
81b30000 22dfe 804a4e8 — proc/boot/more=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/bin/more
81b53000 1f0b 8048918 — proc/boot/hostname=/home/shartmann/qnx660/target/qnx6/armle-v7/bin/hostname
81b55000 6064 8049a30 — proc/boot/use=/home/shartmann/qnx660/target/qnx6/armle-v7/usr/bin/use
81b5c000 2aa8 8048d7c — proc/boot/kill=/home/shartmann/qnx660/target/qnx6/armle-v7/bin/kill
81b60000 15177 804a3a8 — proc/boot/fdisk=/home/shartmann/qnx660/target/qnx6/armle-v7/sbin/fdisk
81b76000 76af 804ade8 — proc/boot/mkdosfs=/home/shartmann/qnx660/target/qnx6/armle-v7/sbin/mkdosfs
81b7e000 9358 804ab94 — proc/boot/waitfor=/home/shartmann/qnx660/target/qnx6/armle-v7/bin/waitfor
81b87358 4 ---- — Image-trailer
make[1]: Leaving directory `/home/shartmann/qnx-ide-5.0-workspace/ti-am335x-beaglebone-SDP6.6/images’
done
09:19:17 Build Finished (took 2m:23s.197ms)
beaglebone.build (28.4 KB)
I might be incorrect but when I played with the Panda board and QNX the correct format of SD was on the QNX site but you had to register. At that time 2010 QNX was a commercial product. Your talking about modify source code that’s not open source I think you might want to make sure what your doing is Allowed
I think it is an error in the BSP makefile somewhere. I went back and found all the executables and shared libraries that were built as part of the BSP and saw that on my build host, none of them had execute permissions. I did a “chmod +x” on all of them, removed the .bin image file, did a build in the IDE, and that seems to work much better.
I don’t know, though, if I should fix the makefile to create the local files with execute permissions, or if there is a command or directive I can use in the .build file which would set the permissions properly in the image.
These lines in the .build file should start the SD and eMMC:
I just downloaded and built the latest ‘experimental’ QNX 6.6 BSP for BBB. Got the same errors. Turns out that the permissions of files in install/sbin and install/bin needed to change. Once I changed their permissions, all goes well. The build script does not mount the SD card or the eMMC, so that must be done manually.
This is a bit off-topic, but: what is the state of QNX at the moment? Last time I have seen it, it came with a very poor X-Server interface which caused strange crashes. And it was not possible to compile and use a platform-independent GUI-toolkit like wxWidgets with QNX. Has this changes meanwhile or is QNX still a closed universe where all the necessary standards do not work?
I contacted the QNX folks. They asked for some info on the permissions and how you were running the script, so it seems they were on the right track. Guess you’ve got it all going now?
They also said they’d work with me on refreshing the info as it is a bit stale.
