I'm not trying to be picky. Just pointing out all the little errors I
find as I go through the schematic and try to make my own beagle
board. I notice the R67 which has the symbol of inductor but the
prefix designator of a resistor is actually an inductor.
The PCB has the part labeled as a resistor. But we found in test that it needed an inductor. As we had thousands of these boards in stock at the time, we felt scrapping the boards for this reason was not a wise financial decision and the potential forced letter revision of such a change was costly as well. So, we left it as it is currently today.
I have no plans to fix this in the design. The Beagle is in maintenance mode and there are no plans for any changes to the PCB. I will see if I can add more description to explain the scenario behind the error to help with this confusion. Feel free to fix in on your version of the board.
