I am using a BB-xM and noticed a strange problem.
Using a TP-LINK TL-WN321G wifi dongle causes the BB to reboot immediately after uploading the firmware to the dongle!
I have this same dongle working on an ARM9 S3C2440, so I guess it should work with BB and there are no arch problems.
Here is my output:
running “ifconfig wlan0 up” reboots BB, as you see:
root@beagleboard:~# ifconfig wlan0 up
[ 254.633331] rt73usb 2-2.2:1.0: firmware: requesting rt73.bin
[ 254.833129] ADDRCONF(NETDEV_UP): wlan0: link is not ready
root@beagleboard:~#
Texas Instruments X-Loader 1.4.4ss (Aug 19 2010 - 02:49:27)
Beagle xM Rev A
Reading boot sector
Loading u-boot.bin from mmc
Before running “ifconfig up wlan0”, my configuration is:
root@beagleboard:~# iwconfig
lo no wireless extensions.
usb0 no wireless extensions.
wlan0 IEEE 802.11bg Mode:Managed Access Point: Not-Associated
Tx-Power=0 dBm
Retry long limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:on
dmesg tail (before crash):
[ 17.081024] usb 2-2.2: New USB device found, idVendor=148f, idProduct=2573
[ 17.088348] usb 2-2.2: New USB device strings: Mfr=1, Product=2, SerialNumbe0
[ 17.095916] usb 2-2.2: Product: 54M.USB…
[ 17.100555] usb 2-2.2: Manufacturer: Ralink
[ 17.798950] udev: starting version 151
[ 19.012634] cfg80211: Using static regulatory domain info
[ 19.018066] cfg80211: Regulatory domain: 00
[ 19.043243] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_)
[ 19.050811] (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 19.076110] (2457000 KHz - 2482000 KHz @ 20000 KHz), (600 mBi, 2000 mBm)
[ 19.090911] (2474000 KHz - 2494000 KHz @ 20000 KHz), (600 mBi, 2000 mBm)
[ 19.106353] (5170000 KHz - 5250000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 19.121795] (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 19.128936] cfg80211: Calling CRDA to update world regulatory domain
[ 20.891143] phy0: Selected rate control algorithm ‘pid’
[ 20.891754] Registered led device: rt73usb-phy0::radio
[ 20.897766] Registered led device: rt73usb-phy0::assoc
[ 20.903228] Registered led device: rt73usb-phy0::quality
[ 20.911315] usbcore: registered new interface driver rt73usb
Distro:
Angstrom 2010.7-test-20100823
#uname -a
Linux beagleboard 2.6.32 #3 PREEMPT Wed Aug 18 15:53:03 UTC 2010 armv7l unknown
root@beagleboard:~# opkg list-installed |grep rt73
kernel-module-rt73usb - 2.6.32-r90+gitra6bad4464f985fdd3bed72e1b82dcbfc004d78696
rt73-firmware - 1.8-r1.6
Anyone had this kind of problem? Any ideas?
thanks
