Hi!
I’m using the v3.8.x branch from RCN with a BBB clone based on am3352 with 800MHz factory rate. I can see that under heavy load the frequency goes up to 1GHz while it should be limited to 800MHz. Can anybody suggest a way to limit the frequency in the kernel?
I did some testing and setting the cpu frequency with the below command does limit it. Using sysfsutils and editing /etc/sysfs.conf to include these lines:
devices/system/cpu/cpu0/cpufreq/scaling_governor = ondemand
devices/system/cpu/cpu0/cpufreq/scaling_max_freq = 600000
sets the frequency at bootup. However the cpu still runs at 1GHz for a few seconds before these settings take effect, so I think we need a kernel change to fix this
