Did you use external power-supply?
Yes, I have a 5V bench supply plugged into the DC jack.
Greg,
Do you have external power to your USB hub as well? BeagleBoard can
only source 100 mA which is not enough for multiple devices.
For more suggestions, see BeagleBoard wiki and FAQ:
http://elinux.org/BeagleBoard#USB
http://elinux.org/BeagleBoardFAQ#USB_OTG_connection_.231
Hope this helps.
John
I plugged everything back in today and the usb worked without any
problems. I think it might be a bad cable, or some sort of hardware
problem. If the problem re-appears, I'm going to try replacing cables
and hub.
John: I am using a powered hub. I've been reading quite a bit on the
elinux wiki and it has been a great help.
Thanks for the help everyone.
