I’ve only used CAN1 since the I2C for Cape ID isn’t something I wanted to lose.
The Beagle that was running with the CAN cape had its SD card die so I lost the configuration information. But this site here does a pretty good job of explaining what is needed.
https://www.beyondlogic.org/adding-can-to-the-beaglebone-black/
I did not see the same information as the web page when I looked at dmesg.
debian@beaglebone:/dev$ dmesg | grep -i can
[ 0.851243] CAN device driver interface
[ 0.975646] can: controller area network core (rev 20170425 abi 9)
[ 0.982999] PM: Cannot get wkup_m3_ipc handle
I’ve got a cape from Logic Supply on this beagle but it’s not found at the moment on this new 4.14 installation. Following the web page…
debian@beaglebone:/dev$ config-pin p9.24 can
P9_24 pinmux file not found!
Pin has no cape: P9_24
Ever since $SLOTs concept was trashed on the Beagles the Logic Supply user manual for the CBB Cape is useless for installing the device but I’ve included the dts in case that will help.
At the moment I have no idea how to even ask the Beagle if it has seen the cape installed. I can see it’s connected physically. I put the beagles into their kennel last summer and before that they spent more than a year in isolation. Now they are out again and I’m working through Derek Molloy’s book so at some point I’m sure the cape will be seen.
My other Beagle may well have worked with the CAN cape at one point but it doesn’t have the cape installed.
debian@ebb:~$ dmesg | grep -i can
[ 1.015868] CAN device driver interface
[ 1.017132] c_can_platform 481cc000.can: c_can_platform device registered (regs=fa1cc000, irq=42)
[ 1.018405] c_can_platform 481d0000.can: c_can_platform device registered (regs=fa1d0000, irq=43)
[ 1.160062] can: controller area network core (rev 20170425 abi 9)
[ 1.167640] PM: Cannot get wkup_m3_ipc handle
debian@ebb:~$ config-pin p9.24 can
debian@ebb:~$ config-pin p9.26 can
debian@ebb:~$ sudo /sbin/ip link set can1 up type can bitrate 250000
[sudo] password for debian:
debian@ebb:~$
This one doesn’t complain. Again, I’ve completely forgotten what I’ve done.
John
cape-CBB-Serial-r01.dts (3.1 KB)
