With the Cape plugged into the console version it gets to a certain point and then shuts off.
U-Boot SPL 2019.04-g10968f0 (Feb 19 2021 - 21:40:51 +0000)
Trying to boot from MMC2
Loading Environment from EXT4… ** File not found /boot/uboot.env **
** Unable to read “/boot/uboot.env” from mmc0:1 **
U-Boot 2019.04-g10968f0 (Feb 19 2021 - 21:40:51 +0000)
CPU : AM335X-GP rev 2.1
I2C: ready
DRAM: 512 MiB
No match for driver ‘omap_hsmmc’
Some drivers were not found
RTC 32KCLK Source: External.
Board: BeagleBone Black
not set. Validating first E-fuse MAC
BeagleBone Black:
BeagleBone Cape EEPROM: found EEPROM at address: 0x54
BeagleBone Cape EEPROM: debug part_number field:[cape-CBB-Serial]
BeagleBone Cape EEPROM: debug part_number field HEX:[636170652d4342422d53657269616c]
BeagleBone Cape EEPROM: debug version field HEX:[7230310]
BeagleBone Cape EEPROM: 0x54: cape-CBB-Serial-r01.dtbo [0x296d72f]
BeagleBone Cape EEPROM: no EEPROM at address: 0x55
BeagleBone Cape EEPROM: no EEPROM at address: 0x56
BeagleBone Cape EEPROM: no EEPROM at address: 0x57
Net: eth0: MII MODE
cpsw, usb_ether
Press SPACE to abort autoboot in 0 seconds
board_name=[A335BNLT] …
board_rev=[00C0] …
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Scanning mmc 0:1…
Checking for: /uEnv.txt …
Checking for: /boot.scr …
Checking for: /boot/boot.scr …
Checking for: /boot/uEnv.txt …
2062 bytes read in 47 ms (42 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt…
Running uname_boot …
loading /boot/vmlinuz-4.19.94-ti-r42 …
10095592 bytes read in 674 ms (14.3 MiB/s)
debug: [enable_uboot_overlays=1] …
debug: [enable_uboot_cape_universal=1] …
debug: [uboot_base_dtb_univ=am335x-boneblack-uboot-univ.dtb] …
uboot_overlays: [uboot_base_dtb=am335x-boneblack-uboot-univ.dtb] …
uboot_overlays: Switching too: dtb=am335x-boneblack-uboot-univ.dtb …
loading /boot/dtbs/4.19.94-ti-r42/am335x-boneblack-uboot-univ.dtb …
162266 bytes read in 152 ms (1 MiB/s)
uboot_overlays: [fdt_buffer=0x60000] …
uboot_overlays: loading /lib/firmware/BB-ADC-00A0.dtbo …
867 bytes read in 44 ms (18.6 KiB/s)
uboot_overlays: loading /lib/firmware/cape-CBB-Serial-r01.dtbo …
2245 bytes read in 88 ms (24.4 KiB/s)
uboot_overlays: loading /lib/firmware/BB-BONE-eMMC1-01-00A0.dtbo …
1584 bytes read in 315 ms (4.9 KiB/s)
uboot_overlays: loading /lib/firmware/BB-HDMI-TDA998x-00A0.dtbo …
4915 bytes read in 338 ms (13.7 KiB/s)
uboot_overlays: loading /lib/firmware/AM335X-PRU-RPROC-4-19-TI-00A0.dtbo …
3801 bytes read in 278 ms (12.7 KiB/s)
uboot_overlays: [uboot_detected_capes=cape-CBB-Serial,] …
loading /boot/initrd.img-4.19.94-ti-r42 …
6585227 bytes read in 460 ms (13.7 MiB/s)
debug: [console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait uboot_detected_capes=cape-CBB-Serial, coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet] …
debug: [bootz 0x82000000 0x88080000:647b8b 88000000] …
Loading Ramdisk to 8f9b8000, end 8ffffb8b … OK
Loading Device Tree to 8f92c000, end 8f9b7fff … OK
Starting kernel …
[ 0.002172] timer_probe: no matching timers found
[ 0.196489] l4_wkup_cm:clk:0010:0: failed to disable
